06-24-2018, 03:24 PM | #1 |
Help - Distributor Won't Turn to Adjust
Been trying to set the timing on my L6 engine. It runs poorly, but it runs. I loosened the bolt holding the distributor shaft and made sure the little fork had free play. I can't for the life of me turn the distributor to adjust the timing. It's stuck. It's an awkward thing to grip with tools so I thought I'd check for ideas before I damaged something.
Present: 2015 Tacoma. Yeah, not a GM, but I love it. 1969 GMC 32,000 - fix, drive, relax, fix... 2019 BMW R1250 GSA - Yahoooooooo 1979 Honda GL 1000 - retro touring at its best. Past: '05 Sierra 4x4 - Had 270,000 KM and running well when it was written-off by a stop sign runner. '94 F-150 from the "F word" company. I'll admit it...good truck. Sold what was left of it for $800 to a guy who came to pick it up at 11:00 PM with cash in hand. Hmm. '79 Sierra Grande (Black) organ donor - perfect rebuildable 4-bolt 350 and a good TH350. '76 Sierra Grande (Orange) - hate isn't too strong a word. Kid who bought it turned it into a hot rod. '68 C-10 R.I.P. - Dad's old truck...too far gone to resurrect. '59 C-50 - with hoist. Truck is gone, wife isn't. Nuff said. |
06-24-2018, 03:31 PM | #2 |
Re: Help - Distributor Won't Turn to Adjust
Tap on the vacuum pot with a chunk of wood lightly.
Hammer handle will. Work. |
06-24-2018, 04:49 PM | #3 |
Spray PB Blaster at the base right there were you took the fork loose.
Remove the fork and use a set of good channel-locks. Be very careful. Try one direction then flip channel-locks and try the other way. You may choose to remove oil filter to give you a little more room. Maybe it will work without that unless you need to change the oil anyway.
06-24-2018, 05:24 PM | #4 |
How many coats of paint are covering the base to block mating area?
Run a razor around it to loosen it up. Bill
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
06-25-2018, 11:30 AM | #5 |
did you actually put a timing light on it yet or check if points and vacuum can are ok? cant imagine the distributors been in the wrong position for so many years that its seized in there
1970 short step c10 leaf spring 454 |
06-25-2018, 02:19 PM | #6 | |
06-25-2018, 02:21 PM | #7 |
It moved two years ago when I last worked on it. I didn't get it running well but had to park the truck due to other commitments. Trying to get it going now. I'm baffled about why its stuck. Didn't do anything strange last time.
06-25-2018, 02:35 PM | #8 |
Does it turn at all in either direction?
06-26-2018, 03:12 AM | #9 |
Dissimilar metals will corrode together almost forming a type of weld. Have faith in the PB stuff.
06-26-2018, 12:13 PM | #10 |
No. It's solid. Two years ago I did some adjustments and it turned fine. It's solid as a rock and I can't budge it...and I've got a very strong track record of "budging" things.
06-26-2018, 12:14 PM | #11 |
That's a good reminder. Add heat and whatever crap has accumulated and you can get a pretty strong bond. I've just been blasting it when I get home from work and I'll see if it moves when I have time on the weekend.
06-26-2018, 04:22 PM | #12 |
Can you turn the crank?
06-26-2018, 04:25 PM | #13 |
sounds like the engine is frozen ? Smack it with a big hammer and upgrade to hei .
06-26-2018, 04:58 PM | #14 |
Engine turns, dist doesn't.
06-26-2018, 07:32 PM | #15 |
So the rotor rotates when the engine turns?
07-03-2018, 02:56 PM | #16 |
Fixed it! Time and persistence paid off. I’ve been blasting it with penetrating oil every time I remembered. Today I removed the oil filter for better access and used a flat punch to tap wherever I could. Then I put a pair of vice-grips on the shaft and used muscle power to slowly break it free.
Now, just need to charge the battery so I can start it and set the timing. Just another lesson in patience - one that I need to learn.
07-03-2018, 04:03 PM | #17 |
Good news.
07-03-2018, 04:40 PM | #18 |
Id pay to see this setup!
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
07-03-2018, 09:17 PM | #19 |
Did the last person to R+ R the distributor forget to put down the gasket? Or was the old gasket glued down w/ RTV or ''supersnot'' [3M Weatherstrip Adhesive]?
If there wasn't one there, you need to get a gasket. The ID is about 1-1/8'' and the OD is about 1-1/2'' --roughly. I think it's the same diameter as the V8, but I coulb be wrong. At any rate you need a new one. Put a dab of motor oil on both top and bottom surfaces before you put it down. Then you won't get this gripe again.
