04-17-2021, 10:08 PM | #1 |
Front brake hose fitting 74 C20
Can anyone tell me what fitting would go on this line?
1963 C20, small window, long bed 292, 4-speed |
04-18-2021, 09:51 AM | #2 |
Re: Front brake hose fitting 74 C20
Is it for a 74?...most likely not metric...maybe...
Are you referring to the line fitting size I'm guessing the line size will be 3/16...which most probably will have a 3/8-24 thread size fitting on it.. be aware, you can also get different thread size fittings for 3/16 Or are you referring to the od threads?
04-18-2021, 09:59 AM | #3 |
This shows maybe 5/8 fine thread for the od threads...
http://67-72chevytrucks.com/vboard/s...d.php?t=177184
04-18-2021, 11:55 AM | #4 | |
Just not sure what fitting I need to go to the brake lines. Hoping someone here can post a couple pics.
04-19-2021, 10:22 PM | #5 |
Should be 3/8-24 inverted flare brake line fittings
The ends will look like this
04-20-2021, 07:23 PM | #6 |
From the factory, a stamped nut was used but you can use a 5/8"-18 nut
04-20-2021, 08:48 PM | #7 |
I think I can just use what’s on the truck when I swap the cross member.
04-20-2021, 09:39 PM | #8 |
5/8-18 jam nut to hold the hose to the frame and regular 3/16 brake line + fittings for the hard line
