Old 05-08-2015, 12:47 PM   #1
eighteenninetytwo
Serpentine belt systems on 350 small block
anyone fitted one of these?
http://www.lmctruck.com/product-page...cta_serpentine
eighteenninetytwo is offline   Reply With Quote
Old 05-08-2015, 07:33 PM   #2
riz
Re: Serpentine belt systems on 350 small block
I just got an email from LMC today that showed these...........A bit pricey at around $2000 but it sure would be nice.
RIZ
Originally Posted by eighteenninetytwo View Post
riz is offline   Reply With Quote
Old 05-09-2015, 01:07 AM   #3
lightningtruck
I purchased a March serpentine belt setup for a SBC about 10 years ago.
Looks great but is a pain. Ac belt vibrates. PS cap is hard to access....
I have had great luck with the stock chevy serpentine systems. I went to the pick and pull and took it all off a 1990 suburban. But the LMC one comes with all the good accessories! I'd like to see some reviews too.
Mike McGinnis
1990 V3500 Crew Cab build http://67-72chevytrucks.com/vboard/s...d.php?t=559196
1983 C10 Step Side Old Friend http://67-72chevytrucks.com/vboard/s...45#post7266145
lightningtruck is offline   Reply With Quote
Old 05-09-2015, 01:17 AM   #4
gmachinz
I like custom stuff too but I can't justify a 2K serpentine kit. The GM kits are a proven design and look good if you detail them.
gmachinz is offline   Reply With Quote
Old 08-16-2015, 06:15 PM   #5
jobberone
can you use 85 or 87 to 93 or 95 GM belt systems from any SBC truck for my 76 K10?
jobberone is offline   Reply With Quote
Old 08-17-2015, 12:06 PM   #6
OutlawDrifter
i would go with the stock stuff cleaned up, can be had for pennies on the dollar and very functional.
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 08-19-2015, 09:47 AM   #7
notsolo
notsolo's Avatar
X 2 Buy stock.... clean it up and get it powder coated..Save $1500.00.
notsolo is offline   Reply With Quote
Old 08-22-2015, 07:44 AM   #8
silverbear
silverbear's Avatar
Just a word of caution. Look at your block and head configuration before grabbing parts from a pick-a-part yard. There are factory brackets that keep the alternator on the passenger side and a/c compressor on the drivers side. This style requires your passenger side head to have three mounting bolt holes for the alternator and tensioner bracket. The a/c and power steering bracket will bolt up fine. This style of brackets were the first ones I picked up and since my heads have three holes on one end and one on the other, like most older heads do, I could not use them. (I have these brackets listed in the classified section if you want to look at this style)
There is a another style out there that has the alternator on the driver's side along with the power steering pump. The a/c compressor is mounted on the passenger side with the belt tensioner. These will bolt up better to the older style block and head but you will have to rework your wiring and a/c lines. The wiring kits are available in the classified section if you don't feel comfortable doing all of that yourself. What I like about this style of set up is that with a couple of adapter brackets you can upgrade from the R4 compressor to a Sanden 508 style.
With either style of brackets there is a pulley available to mount in the place of the compressor if you are not running a/c.
86 Chevrolet K10 350/SM465 Frankie SOLD
1995 GMC Yukon GT SOLD
1996 GMC Yukon GT
2010 Suburban 1500 4x4 5.3l/6L80e. Sold
2016 Silverado 2500HD Crew Cab 4x4 6.0l/6L80e
silverbear is offline   Reply With Quote
Old 08-22-2015, 07:50 AM   #9
silverbear
silverbear's Avatar
Those kits look very nice but i don't like how little of the belt comes in contact with the crank pulley. Not enough contact with the drive pulley could cause the belt to slip and squeal (IMO).
1996 GMC Yukon GT
Old 08-22-2015, 07:57 AM   #10
Big Blue
Big Blue's Avatar
Silverbear, What did you get it off of ? Year and make.
I have the type with two holes on one side and three on the other head. I have the Older style 350.
John
Big Blue ( John )
79 Chevy Pick up.....My Dailey
STILL Working on a frame up: 1987 Truck body on a 78 Blazer frame. Need cab blasted to start project. Got the cab BLASTED, Now Prep and Paint. Started to lay SOME BONDO and primer. Done, Ordering paint. Got paint, Stuff painted,Cab,Fenders, Hood more later. 9/7/2015 Got the clear coat on,now time to take one off. Started to put things back (What a nightmare) like the heating and AC stuff,inside wire harness, outside AC unit and booster, still more. May 2016, still working on the inside. Got duck work in,heating and AC. Radio (stock) in dash with after market in console later, Speaker are hooked up, Steering column is in. Getting ready to drop the cab onto the frame, Working on engine now since I have the room. Well here it is 2018, got the engine in and it runs, now I need to get the exhaust system in so I can adjust the lifters, to loud right now. Got the exhaust on now I am waiting for the break parts to come in.
Big Blue is offline   Reply With Quote
Old 08-22-2015, 08:08 AM   #11
silverbear
silverbear's Avatar
John
The first set I traded for them from a buddy who was upgrading to a March set. I was told they were off of later 90s pickup. The second set (with the alternator on the drivers side) came out of early 90s pickup.
1996 GMC Yukon GT
Old 08-22-2015, 08:16 AM   #12
silverbear
silverbear's Avatar
Here is the first set I got that will not work if you only have one bolt hole in the passenger side head.
1996 GMC Yukon GT
Old 08-29-2015, 05:06 PM   #13
87Skier
87Skier's Avatar
Looks like the same setup I have on my 72. From a 1996-1998 Chevy truck I presume? If so mine works great. Let me know if you need help with the later alternator wiring, its a CS130D alternator I think.
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205
1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears
1996 Chevy Suburban K1500 350/4L60E
87Skier is offline   Reply With Quote
Old 08-29-2015, 05:24 PM   #14
UKNOWME
UKNOWME's Avatar
I have the GM kit on mine and it looks and functions great!
Not sure why gmachinz didn't reference his for sale thread http://67-72chevytrucks.com/vboard/s...d.php?t=676344. Although the OP has never responded after his 1st post so maybe he doesn't care anymore.
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 11-02-2015, 04:25 PM   #15
DD1
Your setup looks great. What type of truck are your radiator hoses for? I got a serpentine setup from an early 1990's Chevy truck. Wondering if I should get hoses to match the 1990 truck so they route around the serpentine setup properly? Or should I get hoses for the actual truck, a 71 C10?
___________________________________________
Darien
1971 C10 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=502964
DD1 is offline   Reply With Quote
Old 11-03-2015, 03:10 AM   #16
mcmlxix
Collector of Projects
mcmlxix's Avatar
I have a serp setup that came on my 78 Blazer. My hose isn't the best fit so I'm open to suggestions.
Also, my serp bracket has a spot for something under the passenger side AC bracket. I don't know what would have gone there. Maybe a smog pump?
Rich
1972 K5 Blazer CST Click HERE
Old 01-12-2021, 08:18 AM   #17
C10DREAMER
Any pics of serpentine setup with air gap intake ?
C10DREAMER is offline   Reply With Quote
