Old 06-17-2019, 03:14 PM   #1
rickywideglide
rickywideglide's Avatar
air bag compressors tripping breaker
installed rear air bags in my 1964,dual compressor ,has 60 amp circuit breaker,with truck running breaker will flip before tank is full @ 90 psi,relays seem warm to touch,any ideas to resolve this?i believe the relays are 40 amp,this was a full air ride kit,but only did rear,
rickywideglide is offline   Reply With Quote
Old 06-19-2019, 11:51 AM   #2
SCOTI
SCOTI's Avatar
Re: air bag compressors tripping breaker
What size wiring? What length between breaker, power source, & compressor/s?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-19-2019, 07:40 PM   #3
rickywideglide
I followed schematic shown,6 ga wire is about 7 feet from breaker to relays . should I separate grounds for relaysName:  0619191932.jpg
Size:  27.7 KB and compressors?
Old 06-20-2019, 02:25 PM   #4
SCOTI
SCOTI's Avatar
Originally Posted by rickywideglide View Post
I followed schematic shown,6 ga wire is about 7 feet from breaker to relays . should I separate grounds for relays and compressors?
I'll look @ my schematic but I remember tying my grounds together for the comps & relays. I do however have 'over-kill' as far the remainder of my GROUND system:
Engine block to frame = Each side of motor has 4ga batt cable to the frame (L&R rails ground to block).
BATT @ PASS rail & cab (relocated battery).
Frame rails to core support = 4ga (again, both sides).
Cab to frame rails = 4ga (both sides).
Rear x-member welded to rails.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-20-2019, 06:57 PM   #5
PGSigns
PGSigns's Avatar
Run a dedicated round and see if that fixes it.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 06-22-2019, 08:16 AM   #6
rickywideglide
thanks for replies, gonna mess with it this weekend
Old 06-29-2019, 07:02 PM   #7
rickywideglide
ending up changing 60 amp circuit breaker with a better brand,went to lower psi pressure switch,been working like it should,still gonna add better ground from batt. to frame
