05-31-2019, 08:28 AM | #201 |
Re: Shop truck build
Wow! How'd you trick her? Nice work on all fronts!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
06-09-2019, 10:47 AM | #202 |
Congrats
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
06-20-2019, 09:38 AM | #203 |
Well, first and foremost, congratulations on the marriage!
Now, on the truck front; would you care to share some details on that dash? What did you find was the best method of stripping the old padding off? Rip/tear and sand? That look is exactly what I was thinking for my dash since my dash pad is... bad... to say the least. |
07-03-2019, 10:50 AM | #204 | |
Man, I am behind on updates...I apologize fellas, and I will get caught up over the next couple days...but 1st
Basically, I went crazy with a putty knife.......FOR HOURS!!! I can't remember the exact number but there are over 70 of those stamped holes in the dash (I am guessing for weight reduction) that are very sharp and left me with several finger slices... The black mesh is gutter guard that I picked up at Menards and JB Weld'd to the bottom...cheap and doesn't look too awful... The wood accent is actually 100yr old barn wood that I planed down and trimmed up to fit the existing trim holes... I know that Gregski stripped his down in his Restoring Rusty thread and I believed he was phosphoric acid, but I can't remember exactly...
Just a Hillbilly in the Hood http://67-72chevytrucks.com/vboard/s...d.php?t=622194 |
07-05-2019, 10:07 AM | #205 | |
Thanks! I wound up peeling it all by hand, then using flat head screw drivers on the stubborn stuff, then sandpaper to get the remainder off. It took probably 2 hours or so to get it to paintable condition.Sprayed with flat black rust converter... I haven't done the gutter guard yet, but also agree on the sharp edges! Looks way better than what was there before. |
07-05-2019, 11:34 AM | #206 |
I did the same to my dash... post #132 bare metal, then i bought custom aluminum one
My build thread... http://67-72chevytrucks.com/vboard/s...d.php?t=515829 Disabled Veteran 82nd Airborne Division Operations: Desert Shield, Desert Storm, and Uphold Democracy |
07-06-2019, 03:57 AM | #207 |
Congratulations on gettin' hitched! Good catch!
And the motor looks good "perched" in its newly cleaned environs. |
09-10-2019, 09:16 PM | #208 | |
I'll start with the Sniper EFI...quite simply, this thing Rocks! Total install (fuel pump and fuel lines) and wiring time was about 2 hours - it was a bit easy because of Rusty's lift. Truck fired on the 1st turn and it took about 10 minute for the computer to "learn" the motor...them puters have come a long way since my ole Commodore 64... The only complaint about the system is the same one that everyone else has...The pedal is STIFFFFF and the throttle response takes a bit getting used to...all four flaps flap at the same flapping time! Sooo, at intersections you either creep through like your 98 and fell asleep waiting for the light to turn or you are spinnin your one legged beast like a 16 yr driving his cheerleader girlfriend's mustang... I just ordered the progressive link that Holley does not recommend and I'll let you know how it works...everybody says it makes things mo better and everybody is always right... Other than that, the truck fires immediately, there's no quadra-junk stumble, no gas fumes (kinda miss that) and it just works!
09-11-2019, 07:41 AM | #209 |
Send the progressive link back an order the throttle arm extension. That's what you actually need. I tried the progressive link an didn't like it. I have since found out you need to do more tuning to the system for it rather than just checking the box an telling it what % the rear opens. Mine didn't open the rear until 52% throttle which was way to late imo, it needs to be more like 22-25%. Hope your results are better with it but I think you'd be happier with the arm extension.
If you are dead set on keeping the progressive link I can help you get the tune set up for it after you install it.
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded '03 burb. Family cruiser http://upstategmtrucks.com/ |
09-11-2019, 08:12 AM | #210 | |
I'll report back...thank you...
09-11-2019, 11:46 AM | #211 |
The fuel Injection badge is pretty cool.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939 87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html 04 1500 crew cab http://67-72chevytrucks.com/vboard/s...d.php?t=786514 |
09-11-2019, 11:56 AM | #212 |
65 Vette badging...wanted sumptin different
09-11-2019, 12:05 PM | #213 |
I was thinking Vette. I have a '72 J10 badge on my Jeep that I really like. I just need to find the other one.
09-11-2019, 12:07 PM | #214 |
Now that! is cool!!
09-11-2019, 01:24 PM | #215 | |
An the guys saying it will help on mileage are full of it. The engine needs a certain amount of fuel to run. It can come from all 4 injectors or 2 but it's still going to use the same amount of fuel. I went an took Holleys efi classes (through level 2) in August so if you get stuck on anything just shoot me a PM. If you haven't found it already I recommend saving this manual. http://documents.holley.com/techlibrary_199r11259.pdf If you do Facebook avoid the sniper groups. Its full of people who can't/won't read the manuals an want to argue about why you have to do certain things the way it says. I won't get off on that rant though lol.
09-11-2019, 04:57 PM | #216 |
Redneck tip of the day...lost center caps? Steal the caps off your neighbors fence, wire wheel them, wrap the base in electrical tape and slam them in the hole! Better than spending $50 per on new ones... .
09-12-2019, 09:35 AM | #217 |
Now you have made us all accomplices in your criminal activities... thanks
09-13-2019, 08:40 PM | #218 |
Thanks for all the info.
09-14-2019, 07:39 AM | #219 |
In the "you get what you pay for but sometimes cheap works" category...we have this radiator...
Fitment was perfect and install was pretty simple...had to fab up some top brackets out of a piece of metal door trim (yes...that bracket is SEMA quality, I know), but it settled in place nicely... I knew sumptin would go wrong with this piece and it showed itself when the trans cooler outlet threads stripped out immediately...no biggy...picked up a junkyard external and all is right in the world... Next issue was getting this baby to burp...she didn't want to...took a while and she made sure to spew multiplemany times... Really, this unit works pretty well (he said unit) for what it is...in normal, stupid traffic during hot days, it keeps the motor about 185 degrees...if I am running the A/C (don't judge), it hovers around 205 but I gotta keep an eye on it in heavy traffic... All in all, I cain't complain...$255 for a radiator/fan combo...I'd by that for a dollar...
09-18-2019, 07:19 PM | #220 | |
09-20-2019, 07:42 AM | #221 |
Glad it helped. They should include that extension part with them imo...
01-20-2020, 01:50 PM | #222 |
saved these seats from a Caddiwack...
01-21-2020, 01:49 PM | #223 |
Oh...those are nice
03-19-2020, 03:32 PM | #224 |
finally getting around to installing the buckets...doing a little mock here...
04-12-2020, 05:53 PM | #225 |
Seats installed and some "paint" clean up with boiled linseed and mineral spirits...
Gonna lower the rear some more and go with a posi rear end...I'll detail the work...
