06-19-2019, 01:41 PM | #1 |
Wiring a steering column
I got an EZ 21 circuit wiring harness and I've got it roughly laid out in my truck. I'm using a1970 steering column. Just put in a new turn switch and got a new neutral safety switch too.
The EZ harness has connectors for GM columns, and I bought the adapter for the turn signal switch to plug into. Problem is that the EZ harness isn't preplugged. I have to insert the wires into the connector myself. Which wires go where? I could line them up if someone could provide a diagram for the steering column.
1950 Build |
06-19-2019, 02:54 PM | #2 |
Re: Wiring a steering column
Wiring diagrams are available on this site.. Did you try using the search feature at the top of this page?? The diagrams can also be found in the service manuals.. You didn't say what year truck you're working on so my information is just a shot in the dark.. Try looking here:
http://67-72chevytrucks.com/vboard/s...d.php?t=185856 |
06-19-2019, 03:04 PM | #3 |
Thank you! It might have been my word choices or word combinations. I was pulling up all sorts of wiring and steering column stuff, just not something like this.
1950 Build |
