Old 12-11-2019, 12:34 AM   #1
Mike1965
Mike1965's Avatar
Factory or Homemade?
I noticed while I taking apart the frame of my '65 C20, that the trailing arms have plates welded to the bottom and top of them. I am wondering if these plates were added for the 3/4 ton trailing arm trucks from the factory or did a PO add these to the truck?
1965 C20 LWB Flatbed Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=795718
Mike1965 is offline   Reply With Quote
Old 12-11-2019, 07:26 AM   #2
PGSigns
PGSigns's Avatar
Re: Factory or Homemade?
I think my 66 C20 had em. Still not sure of the origin of the plates.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 12-11-2019, 10:22 AM   #3
jayoldschool
Moderator
Factory plates on C20 and up.
jayoldschool is offline   Reply With Quote
Old 12-11-2019, 06:39 PM   #4
Clyde65
Clyde65's Avatar
Stiffening plates for the 3/4 ton, idk if factory tho
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 12-11-2019, 11:02 PM   #5
Captainfab
60-66 Nut
All C20's that I have seen had those from the factory to stiffen up the trailing arms. They also have a brace from the front of the trailing arm crossmember over to the frame rail, that is not present on a C10
Old 12-12-2019, 12:01 AM   #6
SkinnyG
SkinnyG's Avatar
Would these reinforcements be something worthwhile on a regular C10?
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is online now   Reply With Quote
Old 12-12-2019, 10:01 AM   #7
60-66
60-66's Avatar
3881314 is the GM part number. C20 from 1960-1972 . Will also work on C10 as this is the later replacement part that was used to repair C10s
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
