03-02-2010, 09:47 AM | #1 |
trucks72
700r4 TCC vacuum switch
Does anybody know where a person can buy these new? GM has discontinued the part number I have. And I have used all the ones that I can find in juckyards around here.
03-02-2010, 10:23 AM | #2 |
Re: 700r4 TCC vacuum switch
try calling bowtie overdrives or painless wiring and see if they have anything
03-02-2010, 11:35 AM | #3 |
gm #8627332? i just ordered it from globalgmparts.com. they called me to tell me that it was discontinued, but the guy i talked to, smitty, said he could still get it. here is the number - 908 757 4000, his extension is 409
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD Using your turn signal is not "giving information to the enemy" 67-72 FAQ Last edited by nightmare; 03-02-2010 at 11:35 AM. |
03-02-2010, 12:19 PM | #4 |
I went to a local aamco and picked one up for 40 bucks, new (GM oldstock) they told me they buy the overstock and discontinued stuff from GM
1967custom |
03-02-2010, 12:37 PM | #5 |
Found these
Ebay http://cgi.ebay.com/ebaymotors/212-3...item3efd2588b8 amazon Amazon.com: ACDelco 212-331 Switch Assembly:...
1967 Suburban 292 3spd 1964 Chevy II wagon 1971 Monte Carlo 402BB 1964 Cadillac series 62 2dr 1964 Bonneville 2dr/ht 1967 GTO 1978 Chevy Van 30 1989 R30 Crew Dually Bonus Cab Last edited by Chevydude56; 03-02-2010 at 12:39 PM. |
03-02-2010, 01:03 PM | #6 |
I recommend buying an adjustable one.
'72 Chevy C10 383, 700r4, 3.73's A little rust never hurt anyone. I consider it weight reduction. |
03-02-2010, 07:59 PM | #7 |
trucks72
Thanks, I will take the part number off the one on ebay and call my Gm dealer tomorrow. I went to the another junk yard today and found 2. But I could use some more. Have alot of people ask to do this to their trans. I did this to one 2wd drive Blazer one time. Guy drove to Atlanta in it. doing 75-80 and got 23 mpg. Thanks to everyone.
03-02-2010, 08:24 PM | #8 |
trucks72...
How is this TCC vacuum swithch being used on the 700r4? |
03-02-2010, 08:33 PM | #9 |
he is using it to automatically lock up the converter when he reaches steady speed in 4th gear. If you have ever watched a vacuum gauge as you drive, when you reach cruising speed the vacuum goes up since you don't have the butterflies open as much. This high vacuum signal will engage the TCC and lock it in, when he steps on the gas to pass, the sudden drop in vacuum will dis-engage the clutch in the torque converter.
03-02-2010, 08:48 PM | #10 |
does this improve fuel mpg at highway speeds? My 72' C-10 could certainly use it.
03-02-2010, 09:24 PM | #11 |
sharp as a marble
I hard wire mine. From the connector at the trans, to a 4 wire stop light switch. Two of the connectors on the stop lite sw. are for the brakes, and are normally open, the other two are to disengage the factory cruise control. I wsire the TCC to the cruise side if this switch. SO< when you are cruising 45+ and you apply the brake the torque converter UNLOCKS. I also wire a toggle switch in line with this so I can manually unlock the converter if I want to. Simple, and it flat works
03-02-2010, 11:49 PM | #12 |
That is the way that I wired mine. Yes it helps with gas mileage...dropped my rpms about 250-300 at freeway speeds.
03-02-2010, 11:57 PM | #13 |
trucks72
That is exactly the way I wired mine. This is how chevrolet done it for years on some of their stuff. It is a cheap and easy way of doing it. I use the brake switch on mine, but some guys do not use it. They just lock the torque convertor in 4th gear only. When it shifts down it will unlock. My fear with that is if yiou hit the brakes really fast it will stall motor. Never tried it that way so I can not say honestly. But the way I see it if it works why mess with it. Simple and not expensive. Payed $20 for 2 switches today.
03-03-2010, 08:49 AM | #14 |
I actually mounted another dimmer switch on the floor so that I can engage mine by foot and still keep my arm around my honey while drivin'.....
03-03-2010, 10:46 AM | #15 |
Summit sells one that is adjustable for @ $80. It comes with instructions to mount it on the side of the tranny but i used longer wires and vacuum line and put it out of sight under the dash and left the allen wrench in it to adjust it "on the fly". I also put a "on-off-on" toggle switch in so I can select auto lockup, lockup off, or locked. It sure is nice to get your tranny to do what you want without a computer.
03-03-2010, 08:09 PM | #16 |
2ndCIB: Do you have a wiring diagram for that on-off-on switch setup?
72 Fleet (died) 78 Step (sold) 55 Step named Fred (sold) 00 F150 68 Step (named El Scorcho by PO) Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932 |
03-04-2010, 05:39 PM | #17 |
Dont have a diagram but here it goes. There are three wires that come out of the plug on the transmission. One Power, One Ground and One "Overide" to lock the converter at any speed. I used a ON-OFF-ON toggle switch. Use the ground side to controll what you want to do by grounding the center terminal (off Position). Hook the ground from the tranny plug to one of the "ON" sides of the toggle switch. Hook the "Override" to the other "ON" terminal. Flip the switch one way and it is automatic by going through the vacuum switch. In the center position it takes away the ground and the converter will not lock up. In the other "on" position it grounds the switch and locks the converter. I know this sounds confusing but when you see the diagram it will kinda make sense (I hope). I used a small toggle from radio shack and mounted it in the hole under the edge of the dash right above the brake release. This keeps the switch out of sight and still in easy reach. I extended the wires from the transmission to under the dash next to the steering column. I ran a vacuum source under the dash and hooked up the adjustable vacuum switch. The switch its self is about an inch an a half square and about a quarter inch thick. It has two wires and a vacuum port with an adjustment screw in the side. I superglued an allenwrench in the adjustment so i can adjust it going down the road. It works pretty well once it is adjusted. Sure does feel good to here the RPM dorp on demand. Hope this helps.
03-04-2010, 07:19 PM | #18 |
sharp as a marble
Dude you are really really smooth!!! I bet she was sitting next to you when you wrote that! I do like the dimmer switch idea, might try that on mine!! HA HA
03-04-2010, 08:56 PM | #19 |
It is the way to go....much easier to have a Dr.Pepper while driving than have to reach down and flip a switch....my opinion. She wasn't next to me, but she would agree, I can assure you. I can honestly say that I am lucky to have a wife that likes my truck almost more than me.....especially since she can ride "middle" on the bench.....now every vehicle has a dang console.
03-05-2010, 09:29 AM | #20 |
Im trying to get mine used to seeing me flip a switch. That way it will look normal until the ejection seat goes off.
03-05-2010, 11:38 AM | #21 |
