02-22-2016, 02:32 AM | #1 |
Re: Saddle up 66 c10
Nice work on the rust repair. Using patch panels looks like it saved you lots of time.
Nik...................____ 62 lwb c10 step-side 261 5 spd .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ my build thread. Sending unit solution |
02-22-2016, 02:37 AM | #2 |
Thanks, although i'm sure it did save me a ton of time I originally though they would fit a bit better but it is what it is, some of my patch panels came with the truck when I bought it which was a plus.
02-25-2016, 02:49 AM | #3 |
Repairs are looking good! I am considering going with KBS Coatings on my frame etc also. Did you just use the Rustseal Product? Did you use their etching solution before applying it?
Keep up the good work and keep the pictures coming! |
02-26-2016, 12:38 AM | #4 |
Yep, I bought the large frame coater kit which includes three products to be used in 3 differents stages first you use the KBS Klean (Cleaner/Degreaser) apply to the surface generously and keep it wet for approximately 10 minutes and be sure to rinse it off with water, second stage is called Rustblast which is a phosphoric acid I believe which is similar to many other products that eat rust and leave a zinc coating over the substrate, you apply this anywhere from 10 minutes to 2 hours I believe depending on how bad the rust is, also DO NOT let this stuff dry on there and don't forget to rinse it off when your done, then you should be able to apply the rustseal anytime you have time within a certain time period, about 30 days if I remember correctly. Make sure to be in appropriate temperature conditions and follow the directions to a "T" for best results. Any more questions just ask, I would recommend KBS to anyone.
02-26-2016, 02:05 AM | #5 |
cool, thanks for the info on their product! One other thing I was wondering about was there are parts of my frame that still have good paint on them, do I have to strip it to bare steel or will the rust blast prep that too?
Thanks again Jeremy |
02-26-2016, 12:26 PM | #6 |
That I am not 100% sure on. But I did run into the same thing what I did was took some aggressive sand paper like 36 grit and scuff the good paint down maybe so a bit of steel is peaking out and repeat the same process you would with rusty metal, this way at least the surface is prepped right and instead of just chemical adhesion you get mechanical adhesion as well. Hope that helps
02-26-2016, 12:57 PM | #7 | |
