03-13-2019, 07:54 AM | #1 |
Suburban frames 1500 vs 2500
Speaking specifically on suburban frames, does anyone know if there is a difference between the two frames?
03-13-2019, 08:59 AM | #2 |
Re: Suburban frames 1500 vs 2500
I don't think there is a difference. It's mainly the running gear that make the 2500 difference.
- Jeff 89' K5 Blazer, 2.5" lift, 35" tires 04' GMC Yukon XL, 3/4 ton, 8.1L |
03-13-2019, 12:59 PM | #3 |
That's kinda what I was thinking but haven't found anything to say either way. I wonder if on the RPO sticker in the glovebox if it says the chassis used. I believe I've seen this on the trucks
04-11-2019, 01:26 AM | #4 |
I've heard the 3/4 ton frames were the same shape, just thicker metal, I have yet to confirm. if anyone has a 3/4 ton and wants to measure the thickness, I'll measure mine in the same spot and see if there is a difference.
'06 2500 HD 4x4. manual transfer case, crank windows. '88 V10 Suburban 4x4,"The Pig Rig" L05, 700r4, NP208, 4x4 beater camper fun truck project. My trucks don't leak oil, they mark their territory. |
04-11-2019, 11:50 AM | #5 |
My understanding is that K-10 and K-20 frames were the same, at least back to the early 1970s. I've had some of both though not at the same time, and the frames looked to be same thickness. I don't recall if I ever actually measured them, but there is an obvious difference in frame thickness between a C-10 and a C-20.
I was advised to just swap to 3/4 ton axles and springs to convert my Suburban to a 3/4 ton (mainly what I wanted was 16" wheels to run Load Range E tires).
Current/past Chevy/GMC trucks: 1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner |
04-12-2019, 11:17 AM | #6 |
04-12-2019, 12:02 PM | #7 | |
Moderator
They are certainly not the same. 3/4 Ton frames are thicker and I'm sure theres other differences as well.
https://www.pirate4x4.com/forum/chev...-strength.html Quote:
Alex 1967 C50 292ci Lumber truck 1967 C50 292ci Dump truck 1967 C60 366ci Fire truck |
04-12-2019, 12:46 PM | #8 | |
I seriously wanted a 3/4 ton but when buying used you take what you can get when you can get it. Most of what we looked at was pretty rough. The one 3/4 ton Burban we found had a tailgate instead of barn doors. It was a 100 mile round trip just to start looking at anything, and a month of Saturdays was overwhelming when the wife/kids want to take an out of state trip soon ... But that was 18 years ago so I guess we did okay. It just needs some TLC now.
