03-29-2008, 01:53 AM | #401 |
Re: PO has me PO'd
Post up your progress, I don't go over to CK5 anymore. Kurt said you have it blown apart
03-29-2008, 02:45 AM | #402 | |
Damn Yankee
Re: PO has me PO'd
03-29-2008, 02:48 AM | #403 |
Re: PO has me PO'd
With the floor patch it runs an extra 8", so you have to calculate your cut and 90 degree bend to match up to the factory seam, this floorboard is already to drop in...Work on your lower A and B, rocker panel and your dun
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 03-29-2008 at 02:51 AM. |
03-29-2008, 03:13 AM | #404 |
Re: PO has me PO'd
Question, I may have to do the full floor replacement. It looks like you have the floor that has the floor supports and braces attached. I had already bought the floor supports so I'm wondering if I can get away with buying the naked floor and weld the supports that I already have to it? Or should I just try to sell all the sheet metal that I have and buy the complete (with supports and braces) floor? The reason I ask is because it's more that a $100 price difference between the two when all that's different is the supports that I already own. That $100 could go towards shipping.
'72 K5 CST Blazer 4x4 in perpetual progress '96 2dr Tahoe 4x4 daily driver, Black Bear Performance tune, 285-75-16 Nitto Grapplers, Magnaflow muffler, K&N Air filter, Bilstein Shocks.........E-fan, DT Tri Y or Pacesetter LTs coming soon |
03-29-2008, 03:18 AM | #405 | |
Re: PO has me PO'd
If it's jimmy bound, you won't need the rear supports
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 03-29-2008 at 03:20 AM. |
03-29-2008, 03:23 AM | #406 |
Re: PO has me PO'd
It's for a Blazer and I'd be in WAY over my head so I'd probably have some body guys do it on the side for me...but the floors are pretty bad and it's even gone up the seat supports which aren't in any pans that I know of. So this looks like the best way to go. I'd just hate to spend $120 more to just get the parts that I already have pre-attached. I'm sure I could handle that much. Btw, this complete floor replacement....pretty much has to be done off the frame correct?
'72 K5 CST Blazer 4x4 in perpetual progress '96 2dr Tahoe 4x4 daily driver, Black Bear Performance tune, 285-75-16 Nitto Grapplers, Magnaflow muffler, K&N Air filter, Bilstein Shocks.........E-fan, DT Tri Y or Pacesetter LTs coming soon Last edited by Blizz; 03-29-2008 at 03:34 AM. |
03-29-2008, 04:03 AM | #407 | |
Re: PO has me PO'd
It may be possible to do it with it still on the frame, considering how the pan drops in from the top
03-29-2008, 04:11 AM | #408 |
Re: PO has me PO'd
You mean if I were to get the complete floor with supports and braces? So then for me, the naked floor would be the best way to go?
03-29-2008, 04:29 AM | #409 |
Can't wait to retire!!
Re: PO has me PO'd
So...are you done yet?
You da man Jim! I can't wait to see this installed. But shouldn't you be working on the Jimmy? You have a deadline you know.
2009 4x4 Chevy Crew Cab 6.0 1989 4x4 Siverado (270,000 miles) 1972 4x4 Blazer 2007 Chevy Cutaway 1 ton 1970 Corvette (sons project) RIP - CLR 10/11/09 |
03-29-2008, 03:18 PM | #410 | |
Re: PO has me PO'd
Thanks Tim, yeah I'm working with the date in mind. You done getting the old girl blasted yet?
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 03-29-2008 at 03:20 PM. |
03-29-2008, 03:37 PM | #411 | |
Re: PO has me PO'd
So I just watch you guys go to town on yours for now. Looking good!
03-29-2008, 03:42 PM | #412 |
Re: PO has me PO'd
Yeah, I know where your coming from, over the years many a project stalled for differant reasons. Hang in there, they usually get back on track, unless you have 5 feet of snow like Kurt
03-30-2008, 02:12 AM | #413 |
Re: PO has me PO'd
Got alittle work dun today, cleaned up some seams. Weird thing is GM put some kinda weldable seam sealer,and where there wasn't any it was rusty, don't know where it went...it stinks when you get it hot
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 03-30-2008 at 02:20 AM. |
04-02-2008, 02:31 AM | #414 |
Re: PO has me PO'd
Update more rusty floor gone
04-02-2008, 05:06 AM | #415 |
Re: PO has me PO'd
so THAT'S what you're doing with the floor. How are you going to brace it once you cut the braces off?
04-02-2008, 05:30 AM | #416 |
Re: PO has me PO'd
I have access to an overhead 'I' beam, thought I could hang the cab by the firewall to give it support. We'll see how it goes, may change my idea as the work progresses. I would like to have the doors on, before I make the final cuts...
04-02-2008, 02:31 PM | #417 | |
Re: PO has me PO'd
got that right Jim... Good news though, 50 degrees and windy today, that'll take alot away. Might I suggest starting up another thread...? This new project deserves it's own spot light for sure. Any more progress made in the basement? I looked across the field at mine the other day. |
04-02-2008, 02:48 PM | #418 | |
Re: PO has me PO'd
I agree on the thread, this is quite a project and one of the first I've seen using the new floor. And Kurt, were you looking at your Blazer or swb, or is there another one that we don't know about yet?
04-02-2008, 02:59 PM | #419 | |
Re: PO has me PO'd
Up there today working on the yellow blazer, as soon as it's done, mines in! |
04-02-2008, 03:01 PM | #420 |
Re: PO has me PO'd
Now that's good news!
04-02-2008, 07:26 PM | #421 | ||
Re: PO has me PO'd
I'm trying to figure out how to put a full floorboard in a Jimmy, and I thought the fit was good here. Maybe if we put in Tim's he'll be ready for the Mich. run From what I can tell, the crossmember is an issue, and you have to cut out the low hump, and shorten the lenght and reflange it to a 90 degree bend Oh yes the one in the basement, forgot about her... new nose job, '67 cowl hood and inner fenders. Scap the '72 grille suround and build new eyebrows to match the '67 hood lenght I'll try to post up pics next time Quote:
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 04-02-2008 at 07:40 PM. |
04-02-2008, 08:03 PM | #422 | |
Re: PO has me PO'd
2009 4x4 Chevy Crew Cab 6.0 1989 4x4 Siverado (270,000 miles) 1972 4x4 Blazer 2007 Chevy Cutaway 1 ton 1970 Corvette (sons project) RIP - CLR 10/11/09 Last edited by Chevyman63; 04-02-2008 at 08:04 PM. |
04-02-2008, 10:54 PM | #423 |
Re: PO has me PO'd
That's it! No more calling me names
04-02-2008, 11:17 PM | #424 |
Re: PO has me PO'd
2009 4x4 Chevy Crew Cab 6.0 1989 4x4 Siverado (270,000 miles) 1972 4x4 Blazer 2007 Chevy Cutaway 1 ton 1970 Corvette (sons project) RIP - CLR 10/11/09 Last edited by Chevyman63; 04-02-2008 at 11:17 PM. |
04-03-2008, 02:15 AM | #425 |
Re: PO has me PO'd
