Old 09-24-2020, 10:53 PM   #1
Keith6987
Front disc brake problem
I have a 72 Blazer front Dana 44. I can’t mount the calipers because the pads seem too thick. I bought rebuilt calipers that look just like the old ones. The piston is retracted as far as possible. Rotors have no wear that I can see.
Are there different widths of calipers or rotors that I may have mixed up? The pads are the same thickness as the old ones ,but are at least 3/32” too thick per pad. I didn’t take it apart, so I don’t know if it ever fit.
Keith6987 is offline   Reply With Quote
Old 09-24-2020, 11:20 PM   #2
truckster
truckster's Avatar
Re: Front disc brake problem
I just replaced my calipers with rebuilt from O'Reilly. My rotors are roughly 1.30" thick and the space from the inner surface of the caliper to the face of the piston is roughly 2.45". I have new pads on them and the piston sticks out of the caliper housing about 1/8" with everything assembled.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 09-24-2020, 11:45 PM   #3
Keith6987
Thanks for the quick info. 👍🏼 My rotors are 1.290 I also have O’Reilly reman Delco calipers , but they are only 2.250 from piston to inner surface. I looked them over before I turned in the cores, but I didn’t measure the inside. So I guess they made different widths ? Thanks again for the measurements.
Old 09-25-2020, 12:03 AM   #4
truckster
truckster's Avatar
I don't know if there were different ones. I know it's shocking, but I have had O'Reilly's give me the wrong parts in the past...
I'll pull one of them apart tomorrow and get exact measurements if you want them.
Old 09-25-2020, 12:17 AM   #5
Keith6987
That .200 difference between mine and yours would be enough to get the pads in. I don’t want you to take yours apart. You have done me a huge favor in getting the measurements. Now I just have to try and convince O’Reilly that these are not the right calipers.
Old 09-25-2020, 12:38 AM   #6
truckster
truckster's Avatar
OK, but let me know. The wheels aren't on it yet and I would just need to pull one bolt to get more precise measurements.
Edit: I took one apart this morning because I wanted to be sure I didn't give you bad info. With the piston depressed, the inside measurement of the caliper is 2.50. The rotor measures 1.30 and the pads (new pads) measure 0.675, including the backing plate. I looked for my receipt but I couldn't find it.
Old 09-25-2020, 02:25 PM   #7
Keith6987
Thanks for the info 👍🏼 So my rotors and pads are the same as yours, but my calipers are .250 narrower. I wish I knew if there was a separate part number for the wider calipers. I have a feeling the guy behind the desk won’t know.😀
Old 09-25-2020, 03:06 PM   #8
Keith6987
Another update...so I have been working with the passenger side caliper. I get the driver side out and it measures 2.5” like yours and fits just fine ...they look the same both are Delco calipers. So I guess I’ll have to go to the store and measure a few. Thanks for your help Truckster 👍🏼
Old 09-25-2020, 03:13 PM   #9
truckster
truckster's Avatar
You're very welcome. Sometimes the rebuilders put the wrong part in a box.
