Old 10-24-2010, 10:49 PM   #76
gkesseru
gkesseru's Avatar
Re: The rebirth of El Scrocho
I purposely did not put the front clip on until everything in the engine compartment was done. The last major problem was to get the headers to seal. I tried everything, filed the header flanges flat, copper, aluminum, etc. They all leaked because they are for either square ports or round ports, while my World S/R heads and the headers have oval ports. Final solution was to use stock manifold gaskets with hi-temp copper RTV on both sides of each gasket. Here is truck with everything but the front clip ready.
72 Fleet (died)
78 Step (sold)
55 Step named Fred (sold)
00 F150
68 Step (named El Scorcho by PO)
Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932
gkesseru is offline   Reply With Quote
Old 10-24-2010, 10:57 PM   #77
gkesseru
gkesseru's Avatar
The truck has inner fenders,firewall, and inside of hood painted body color. I painted the engine in a wrinkle black with all polished stainless hardware and polished valve cover tops. I'm going for the Harley engine look, with a little chrome on wrinkle black. I think the engine will contrast nicely surrounded by a sea of Orange Mettalic.
72 Fleet (died)
78 Step (sold)
00 F150
Old 10-24-2010, 11:16 PM   #78
VA72C10
VA72C10
VA72C10's Avatar
Looks really good! I am going back and forth on doing black with the polished on my block/heads/intake vs painting them body color also and having the polished parts as the only pop...your black engine is making me lean that way...
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 10-25-2010, 09:43 AM   #79
gkesseru
gkesseru's Avatar
Front clip, less hood, is on. Only one chip in the paint, luckily it's under the headlight bezel. I now understand why some guys keep the hood off for a while. Looks too good to hide.
72 Fleet (died)
78 Step (sold)
00 F150
Old 10-25-2010, 10:09 AM   #80
VA72C10
VA72C10
VA72C10's Avatar
Love that last shot! Looks great!!!!!
Old 10-25-2010, 10:14 AM   #81
gcburdic
Restoration Virgin!
gcburdic's Avatar
Looking fan-tab-ulous!!!
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 10-25-2010, 01:24 PM   #82
67 c10 guy
67 c10 guy's Avatar
very nice, love the color
67 C10 longbed 350/th350
13 Ford Fusion 2.0T daily
67 lwb build sold
67 c10 guy is offline   Reply With Quote
Old 10-26-2010, 07:53 PM   #83
dccarpenter
Looks great, thanks for the detailed writeup.
dccarpenter is offline   Reply With Quote
Old 10-28-2010, 12:50 PM   #84
67cheby
67cheby
67cheby's Avatar
wow...i hadnt checked your build in a while, NICE JOB
67cheby is offline   Reply With Quote
Old 10-28-2010, 05:04 PM   #85
gkesseru
gkesseru's Avatar
Got the bumper and hood on. A lot of masking tape and blankets for protection. Only took about 20 adjustments for the hood to close properly, but fortunately no scratches. Thanks go to my wife for her help in getting the hood on.
72 Fleet (died)
78 Step (sold)
00 F150
Old 10-28-2010, 05:18 PM   #86
67cheby
67cheby
67cheby's Avatar
well.... whats the hold up on the bed ......lets get crack-a-lakin !!!
Old 10-28-2010, 06:18 PM   #87
gkesseru
gkesseru's Avatar
Just took the white oak boards to the local Amish sawmill today to have them planed to size.
72 Fleet (died)
78 Step (sold)
00 F150
Old 11-07-2010, 09:10 PM   #88
gkesseru
gkesseru's Avatar
The interior is almost done. The 6 way power heated bucket seats are from a Pathfinder. The 3 point seat-belts are from WESCO. All that's left for the interior is a console between the seats and carpets for the door bottoms.
72 Fleet (died)
78 Step (sold)
00 F150
Old 11-07-2010, 09:31 PM   #89
gkesseru
gkesseru's Avatar
I made the bed-boards last week and took all week to get the finish to where it's acceptable. I like wood that's still wood to the touch but real smooth.
Here's the finish process (after final planing and sanding):
2 coats teak oil cut with thinner for maximum penetration all sides
1 coat all teak oil
2 coats teak oil, tung oil and spar varnish equal parts
I mixed this so the spar varnish would stick to the teak oil and added tung oil which is another penetrating varnish that hardens more than teak oil.
wet sand with 800 grit using more mixture for the fluid, wipe off
wait 2 days, wax with Minwax Paste wax, heavy coat. The wax I can reapply every month or so...
Put the wood bed together yesterday and mounted the bed today. The assembly of the wooden bed was truly a PITA. I don't see how GM could have built these in an assembly line pace. Mounting was a one-man job using a chain hoist and a come-along. I spent a lot of time per-measuring the frame holes to get the wood drilled right. It paid off as all bolts just fell in first time.
72 Fleet (died)
78 Step (sold)
00 F150
Old 11-07-2010, 09:40 PM   #90
spike38
spike38's Avatar
Looks sharp!!
Man that paint just glows in that light.
Spike
spike38 is offline   Reply With Quote
Old 11-07-2010, 09:41 PM   #91
VA72C10
VA72C10
VA72C10's Avatar
Niiiiice! Looking good!
Old 11-07-2010, 10:23 PM   #92
gcburdic
Restoration Virgin!
gcburdic's Avatar
Great job on the wood....how did those WESCO belts work out....did they install okay?
Geoff with a G
Old 11-07-2010, 11:08 PM   #93
gkesseru
gkesseru's Avatar
I had to make 4 90 degree brackets for each end out of L material. The driver side outside had to be located a few inches forward, but all the rest used the existing mount holes. I bought it with the 11 inch bucket seat versions and they look perfect, like they came with the buckets. I'll post a picture tomorrow.
72 Fleet (died)
78 Step (sold)
00 F150
Old 11-14-2010, 07:17 PM   #94
gkesseru
gkesseru's Avatar
Took El Scorcho in this week for a front-end alignment, which went well.
Here's a couple of shots in a parking lot. First time I could do that. Front end has a 2 1/2 drop spindle and one coil cut off. Rear has 4 inch drop springs. Front has about 1 inch of space above the stock bump stops and rear has about 3 inches of space. I think I may try a 1 1/2 inch spacer to drop the rear further. It's cheap for the price of two U bolts, as I already have some square stock thick enough to do the job. I bought the square stock for the bucket seat frames, but the local steel supplier only sold 20 ft lengths.
72 Fleet (died)
78 Step (sold)
00 F150
Old 11-14-2010, 09:34 PM   #95
gcburdic
Restoration Virgin!
gcburdic's Avatar
That's some mean rake right there!!!
Looks great!
Geoff with a G
Old 11-14-2010, 10:46 PM   #96
gkesseru
gkesseru's Avatar
I can get the floorjack under the front end, but there is only about an inch for the handle to pump up/down at first. I went over my first speedbump today and cleared it, holding my breath.
72 Fleet (died)
78 Step (sold)
00 F150
Old 11-14-2010, 10:48 PM   #97
VA72C10
VA72C10
VA72C10's Avatar
I think it will look great with an extra 1 1/2" rear drop. Will still have a nice rake to it.
Old 11-15-2010, 10:41 AM   #98
67cheby
67cheby
67cheby's Avatar
looks great
Old 11-16-2010, 02:57 PM   #99
McClinton527
McClinton527's Avatar
Awesome paint booth style lighting in your shop! being a body shop guy that appeals to me greatly!
McClinton527 is offline   Reply With Quote
Old 11-16-2010, 11:19 PM   #100
gkesseru
gkesseru's Avatar
That's where I got my inspiration, at a local body shop. ...
72 Fleet (died)
78 Step (sold)
00 F150
