Old 02-04-2017, 01:23 AM   #1
KyleSeal
KyleSeal's Avatar
What Backspacing is Ideal for me?
Looking into ordering some either 15 or 16 inch rims for my 70, I currently have a 5.5/7 drop on my truck (not driving yet, still working on paint), and am looking for some original appearing rims on Summit.
I know backspace for stock is 4.00", is this ideal for my drop? Also, should I run a 15 or 16x8 or a 15 or 16x7?
Tips and ideas are welcome!
Thanks in advance.
"Sometimes I do serve as a good bad example. Glad to be of service."
My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809
KyleSeal is offline   Reply With Quote
Old 02-04-2017, 02:05 AM   #2
James the III
Re: What Backspacing is Ideal for me?
16" tires are slowly getting limited in size choices.. keep that in mind..
James the III is offline   Reply With Quote
Old 02-05-2017, 01:08 AM   #3
KyleSeal
KyleSeal's Avatar
I'm thinking of going 16 for the height gains. Ill probably get coker white walls.
No one has suggestions on backspacing?
Old 02-05-2017, 01:18 AM   #4
Robznob11
Robznob11's Avatar
Well your very limited in front if you have drop spindles. Any more than 4" bs on a 15 will rubthe a arms. On rear i run a 15x12 wide with 6.5 bs
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 02-05-2017, 02:01 AM   #5
KyleSeal
KyleSeal's Avatar
Got it. Regardless of 15 or 16, what width should I get? 7 or 8 inch? Any tire price benefits between the two? As stated I am running a 5.5/7. Looking to make this a good driver (yes I know it's low and I can handle it)
Old 02-05-2017, 12:00 PM   #6
Robznob11
Robznob11's Avatar
Honestly your best bet is probably a 7" that way you can run a 225 ish tire. I run a 8" with 255, 60 for the side wall height but that was so wide it rubbed the outer when turning. To solve it i bought 1100$ pb arms to move the wheels in 1". If you go with a 7" you can get a taller tire with out being to wide to rub. You will find that with that much drop a short sidewall puts the xmember and arms way to low for normal driving. I ended up bagging mine for drivability
LED TAILS
backspacing, c10, rims, wheels
