Old 12-17-2017, 04:34 PM   #1
sharkskinman
65 C10 250 stock..high frequency pure tone??
Runs as it should.. no other issues that haven't or will be addressed
It just started
The tone doesn't change with RPMs
If I pull throttle down to 5-600 it goes away
But just start and hear it
Does it regardless of sitting at idle, driving or shifting..etc..
Does not change pitch with movement of clutch or higher RPMs
??? Can't think of anything that would make the sound and Not change at all really with Any changing of anything
sharkskinman is offline   Reply With Quote
Old 12-17-2017, 07:37 PM   #2
geezer#99
geezer#99's Avatar
Re: 65 C10 250 stock..high frequency pure tone??
Vacuum leak.
Old 12-17-2017, 08:07 PM   #3
sharkskinman
Too pronounced top be a vacuum leak
but I'll check
Thought water pump (radiator leak so Only water n it's getting rusty color
But also have a noise sounds like a marble or two when I start till good n warm then every once in a while
