Old 12-13-2017, 02:23 PM   #1
6768chevylover
6768chevylover's Avatar
Dana 44 pinion nut Torque?
I have to replace the pinion seal on my front dana 44 but need the torque spec for tightening the nut up on the yoke?
6768chevylover is offline   Reply With Quote
Old 12-13-2017, 03:49 PM   #2
B. W.
B. W.'s Avatar
Re: Dana 44 pinion nut Torque?
The '71 manual says 210 ft / lbs. Your D44 uses shims to set pinion pre-load instead of a crush sleeve so nut torque is not as critical.
B. W. is offline   Reply With Quote
Old 12-13-2017, 04:03 PM   #3
6768chevylover
Thanks, appreciate it. Merry Christmas! -Mike
Old 12-14-2017, 10:47 AM   #4
A1971Blazer
A1971Blazer's Avatar
One way you can be comfortable with it....take a center punch and mark the nut and the end of the pinion adjacent to each other...measure the distance that threads that are sticking out from the nut....when you put it back on just tighten until the marks line back up...then use the center punch to peen the top of the nut in 2 or 3 places to insure that it doesn't back off....I've done this lots of times....never a failure...
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is online now   Reply With Quote
Old 12-14-2017, 10:56 AM   #5
Bigdav160
Bigdav160's Avatar
Dana's are easy, just torque the nut to specifications. They will weep fluid through the splines so put some silicone between the washer and yoke.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
