01-16-2020, 02:13 AM | #1 |
trailing arms: Goodmark vs. ECE vs. OEM
After doing some research on here, I'm beginning to think my trailing arms are a little too rusty to keep using.
Therefore, I'm looking for a set of new (to me) ones. I was considering pulling the trigger on a pair of the ECE arms. However, people say not to used boxed arms, as they don't flex enough. Not sure how true this is or not. If it's true, that leave me with a) finding a clean set of OEM arms, or b) buying some Goodmark repops on RockAuto. Any opinions here? I'm a little confused based on all I've read. At the end of the day, I'm a pretty original guy so I guess maybe I should go with a nice set of OEM arms if I can find some nice ones close by. Thanks. |
01-16-2020, 04:01 AM | #2 |
Re: trailing arms: Goodmark vs. ECE vs. OEM
A pair of sandblasted trailing arm on the parts board https://67-72chevytrucks.com/vboard/...d.php?t=786364
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
01-16-2020, 08:37 AM | #3 |
Not using boxed arms because they don’t flex enough is a bizarre statement. Eliminating flex allows the suspension to do the work it is supposed to.
IMO, the more rigid the better when it comes to things like trailing arms. I would run the ECE with no worries if that is what you want.
01-16-2020, 11:01 AM | #4 | |
By swapping in hard poly bushings up front vs. rubber, the set-up will bind sooner or will require more flex of the arm. By swapping the I-beam arrangement that allows for some twist in it's length to a solid steel beam that doesn't will induce bind sooner. There are ways to improve the original for sure. The solid steel beam (tubular or square) promotes consistency vs. 'unwanted' flex when subjected to more aggressive loads (side loads/cornering or straight line/drag strip launches). The key to prevent the bind issue is to use a bushing that allows for some flex. Either the OE style rubber (which defeats the intent of eliminating flex) or something that allows articulation w/o being sloppy (a spherical joint). Yes, steel tube arms & poly bushings are a common 'upgrade'. That doesn't mean they are better just because the materials are stronger.
01-16-2020, 11:41 AM | #5 |
i have a set of tubular rectangle trailing arms I installed with new poly bushing , simple and easy install, just make sure you get the correct lube for the bushings. I have had no issues with them at all. I think i got them at ECE.
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
01-16-2020, 03:02 PM | #6 |
So has anyone ordered the reproduction Goodmark arms? They're $200 each at RockAuto, so a little cheaper than the ECE box arms.
01-16-2020, 05:38 PM | #7 |
Seeing your avatar suggests you're in/around AZ? I would think you'd be able to find a clean, rust free pair of T/A's easy.
01-16-2020, 05:45 PM | #8 |
One would think! Heck, I can't even find a rust free cab at a decent price anymore. I think the stock is getting lower out here and is harder to find part-outs.
01-16-2020, 05:53 PM | #9 | |
I'm parting out the OE suspension from my 64 now & will likely clean the crust off the parts & sell them locally. Didn't notice any rust , but wasn't necessarily looking for it either. I suppose I'll look closer just to be sure.
01-17-2020, 05:46 PM | #10 |
Well, I decided on "none of the above."
I wanted to retain the stock look. I don't really trust Goodmark. I also didn't want to be attempting to sand EDP coating off these things. So I went with these. https://www.summitracing.com/parts/c...el/c10-pickup/ CPP seems to have a decent reputation, I maintain my stock look, and they're bare steel so I don't have to sand anything. Plus, Summit is close by, has super cheap shipping, have a discount going now, and I had a coupon. So win - win, I think. Hopefully they work out. Thanks all for the comments. |
01-18-2020, 09:37 AM | #11 |
Let us know how they work out.
I don't buy the no flex from boxed arms being bad. I wouldn't use poly bushings since the point of the boxed arms are to give a more positive feel, as well as more strength. The trailing arm is a rigid member of the suspension. If stock are flexing in up and down motion they are also flexing side to side. They are built to be strongest on the vertical plane. For those lowering trucks, it lessens required range of motion anyway. The fact that 3/4t trucks need that plate tells me the design could use a little help. They are one part of these trucks, which I always say were designed so well, where GM cheaped out and that is showing up now even in AZ trucks. I've only ever run stock trailing arms and have only had a few trucks with them. I never had any problems. But if I needed new trailing arms I think I'd consider ECE's better design.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 01-18-2020 at 09:43 AM. |
01-19-2020, 04:23 PM | #12 | |
If the rear mounting points are @ different heights (driver side goes up 3" & the pass side droops 3") vs both sides moving equally up/down in relation to the front mounts (which remain constant to each other), the triangle needs to be able to flex somewhere to allow the changes. Where does the flex occur to allow the different heights for each side when the suspension cycles? The C-channels can twist slightly along their length (not bend up/down or side/side). That's why I-beams are used. That ability to twist plus the front mounting points encapsulated w/rubber allows the flex. The aftermarket rigid bars/arms don't allow the flex along the length. Poly bushings limit the ability to flex. Stack the two together & it's worse.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 01-19-2020 at 04:32 PM. |
01-19-2020, 06:09 PM | #13 |
If anyone’s worried about the lack of flex in the trailing arms I thought these were a great idea. They replace the bush in the trailing arms and allow less restrictive articulation.
https://www.hotchkis.net/product/196...k=&yr=&md=&sm=
John 69 c20, 396, th400, dana60, ps, ac |
01-19-2020, 06:38 PM | #14 | |
Travis' Tribute Truck - 65 C10 Frame Up Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=495073 |
01-19-2020, 06:44 PM | #15 |
Exactly.
01-19-2020, 07:07 PM | #16 | |
'64 C10 LWB, 283, 5speed '68 C20 LWB, 327, 4speed '69 C20 Custom Camper Longhorn, 350, 4speed '72 C20 Cheyenne Super, 396, TH400 '66 C60, 292, 4speed Last edited by ElKotze; 01-19-2020 at 07:28 PM. |
01-19-2020, 08:13 PM | #17 | |
Yes & no.... Flex beyond articulation is unecessay. Flex for articulation is quite necessary & the triangle (the rear T/A susension on C10's) used the original material choices for that. No flex for articulation means binding. Binding vs. smooth articulation can unsettle the suspension. A suspension that gets disturbed @ the wrong time is unpredictable. On the subject of rear sway bars.... Rear bars are used for specific reasons. Many install a rear sway bar 'because'. Because why? Because it's necessary? Because other guys have one? Because different vehicles have them & this GEN of C10 didn't so adding one is 'better' vs. not having one? If you install a rear sway bar, what size bar are you specifying? A rear bar if needed is supposed to compliment the front so the size up front matters when deciding what rear bar. Adding a sway bar to a T/A set-up that utilizes solid tube arms & non-flex style front bushings won't hurt simply because the set-up is already limiting articulation. It's your truck so use whatever you think is best (solid tube arms, poly bushings, & add a rear bar). Normal driving down the street to the burger joint, Cars & Coffee, or local show won't stress the suspension enough to notice a difference.
01-19-2020, 08:34 PM | #18 | |
'64 C10 LWB, 283, 5speed '68 C20 LWB, 327, 4speed '69 C20 Custom Camper Longhorn, 350, 4speed '72 C20 Cheyenne Super, 396, TH400 '66 C60, 292, 4speed |
01-22-2020, 12:59 AM | #19 | |
Mike 1972 C10 Cheyenne SWB Black Supercharged Project 1972 K10 Cheyenne SWB Copper and White http://67-72chevytrucks.com/vboard/s...d.php?t=654175 1969 Camaro Protouring LS7 T-56 Project Last edited by redbaron; 01-22-2020 at 01:16 AM. |
01-20-2020, 09:00 AM | #20 |
The rear suspension is articulated through the bushed mounts. I have no experience with tubular trailing arms, so I have to ask how drastically do they affect the suspension? What are the negative results?
Hey Aus69, I wondered if something like that was possible?
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 01-20-2020 at 11:06 AM. |
01-20-2020, 10:56 AM | #21 |
Custom made by me with lowering angle included. I've put over 7000km on the truck without an issue.
Do it, Do it right, Do it right the first time |
01-20-2020, 12:08 PM | #22 | |
The following excerpt is copied from the SA Design book on "Muscle Car Handling Upgrades: Rear Suspension Systems": Truck-Arm Suspensions The truck-arm design is another suspension that was never used by OEMs under any muscle car. It was used on many pickup trucks and Suburbans, from 1960 to 1972, hence the name “truck arm.” I mention this system because it has developed a small following in the ProTouring/G Machine segment in recent years. First adapted for use on racing cars by NASCAR legend Junior Johnson in the mid 1960s, it’s still used on every NASCAR Cup car today. The package consists of two very long arms with an I-beam cross section, rigidly attached to the axle with U-bolts and converging in plane view so they’re very close together at the frame mounting point. These arms are quite rigid longitudinally, but fairly flexible in torsion. This is no mistake! In order for the rear axle to articulate, the arms need to twist. This system is in bind whenever it moves, but the geometry and configuration of the arms makes this binding fairly linear. Mounting pads for a pair of coil springs sit on top of the arms just forward of the axle, and lateral axle restraint is almost always handled with a Panhard bar, although a Watts link would also work. Since this suspension is most often used on circle track cars that only turn left, the Panhard bar (usually called a track bar in NASCAR circles) can be used to induce jacking and tune the car’s behavior. This is perhaps the only application where a Panhard bar may be a better choice than a Watts link. About Us: Founded in 1993 CarTech, Inc has become one of the leading publishers of how-to automotive titles for the hardcore enthusiast. In 1995 CarTech purchased the S-A Design line of book from Larry Schreib and Larry Atherton who had published their first book in 1975 titled, The Chevrolet Racing Engine, by Bill Grumpy Jenkins. This single title gained wide recognition as “the bible” of high performance engine design and assembly. CarTech has continued to expand on this tradition and now has nearly 150 titles available for the enthusiast, in a wide variety of formats – from print to digital to video. Today, our publishing efforts include our traditional performance “S-A Design” titles along with race histories, biographies of industry icons; in addition to a number series that further assist readers with their projects. So, using a spherical joint in place of the front rubber bushing allows articulation w/o the instant bind . That being said, spherical joints only articulate so far before reaching their limits as well but that would be extreme articulation (think 4x4 trail climb territory). The factory arms flex is still better for the system in over-all function as designed but structurally stiffer square/round tube works & is more consistent within the range of motion allowed by a front joint that articulates.
01-22-2020, 07:44 AM | #23 |
Do we know there is no flex, sounds like twisting is the key word here, with tubular/boxed design or just less? Are NASCAR arms two pieces of light channel tacked together or are they tubular? I realize roundy round on a race track at 200 mph has different requirements. Very limited requirements compared to road driving.
All I am saying is are the ECE trailing arms really such a bad idea that there is some significant negative affect on performance? Are they really a bad idea? Something we wouldn't want?
01-22-2020, 11:04 AM | #24 | |
Are solid, tubular bars bad? Do they work? Yes. Are they a bad idea? If you know the OE arrangement was designed to achieve their articulation through torsional flex via the front rubber bushings & I-beam construction but delete both of those options from a replacement arm you either need another method that allows articulation or they will bind sooner than the OE stuff would. It's that simple. Will the 'Average Joe' that occasionally putts around town notice? Probably not. But, that does not make them better.
01-22-2020, 06:18 PM | #25 |
This is good conversation guys. Glad we can keep a good discourse on things unlike some other forums I've been on in the past where they tend to get ugly upon the first disagreement.
In any event, I think I'll be fine with the ECE/stock appearing arms. I'm not going to beat my truck, won't probably be hauling anything over 1000 lbs. They should be good. And while I think I could have gotten them when I first posted my question and even pulled the trigger on the CPP arms, the ECE arms are sadly no longer available. |
