11-13-2019, 09:46 AM | #1 |
Big block front seal on my 292
BHJ is making me an SFI damper with serpentine pulley on it. I have Tom Lowe's 2 piece timing cover on it. BHJ tells me that because I have the blower pulley and oil pump pulley hanging out in front that I need to have my cover made to except a big block oil seal. Is the crank the same diameter as my 292. I have a billet crank from Crower that takes the standard seal. Do they make such an item or will a standard big block seal fit my crank? Thank you for your time.
11-13-2019, 02:08 PM | #2 |
Re: Big block front seal on my 292
Checking the Rock auto page the Id/od of a big block (454 in my 77 1 ton) is
Width (in) 0.395 Shaft (in) 2.328 Bore (in) 3 Outer Diameter (in) 3.005 On the 292 there seems to be quite a bit of difference in size from the 454 unit. Material Nitrile Outside Diameter 2.416 in Pieces 1 Seal Type Timing Cover Shaft Diameter 1.763 in Thickness 0.374 IN I'm thinking that they want to go with and OD that they already are dialed in to use and only have to worry about having the bore fit your crank rather than create a complete new setup. The thing is, is there enough material in the cover to safely have it bored to the larger seal od? It appears that there is .589 difference in seal diameter.
11-13-2019, 02:12 PM | #3 |
I checked and the 66 396 engines I have take the same seal as the 454 does. I wanted to make sure that they didn't change over the years.
I can see why he wants to do that though as taking .565 off the od of that piece is going to cut down on it's strength a lot.
11-13-2019, 07:57 PM | #4 | |
11-13-2019, 08:19 PM | #5 |
What if I bought this cast aluminum cover and used it for the center piece. It's only $53. Do a little voo-do and put them together?
https://www.summitracing.com/parts/sum-g6301w |
11-13-2019, 09:51 PM | #6 |
You might check with this outfit to see if they can do you a one off billet cover. Not cheap but if they do them in house it would be reasonably simple to cut one for the larger seal od..
https://mrhotrod6.myshopify.com/prod...ant=1142524689 Another option is if the one you have is the 2 piece unit that 12 bolt Tom is selling you might be able to use that as a pattern to have someone mill another front plate. https://www.12bolt.com/store/p117/2_...0-250-292.html
Founding member of the too many projects, too little time and money club. My ongoing truck projects: 48 Chev 3100 that will run a 292 Six. 71 GMC 2500 that is getting a Cad 500 transplant. 77 C 30 dualie, 454, 4 speed with a 10 foot flatbed and hoist. It does the heavy work and hauls the projects around. Last edited by mr48chev; 11-13-2019 at 10:17 PM. |
11-14-2019, 01:36 AM | #7 | |
11-14-2019, 11:26 PM | #8 |
Good enough, I I have bought from both. Can't decide which one's lump ports I want though.
11-15-2019, 01:45 AM | #9 |
