11-16-2019, 05:06 PM | #1 |
‘78 K10 - Front Axle Not Centered?
Hey, gang. As I’m working through the Suburban, I’ve noticed that the front axle isn’t centered under the truck. I thought I noticed it a few months ago with stock steelies and smaller tires, but recently put 265/75R16 General Grabbers on it and the off-center of the axle is now more obvious. Right hand tire is proud of the wheel well. Driver side tucked in. Maybe 1-1/2” off center.
It definitely seems like drivetrain-to-frame rather than body-to-frame... I’ve noted a few mentions on forum threads that our 4x4 trucks were built with the driveline offset to the passenger side, but I’m suspicious. I do know the front track is wider than the rear. Any thoughts? Truck rides and tracks nice enough down the highway except for a vibration between 65-75mph I’m chasing. Curious, eh? Here’s a pic of the right hand rubber protruding.
Ryan - WANTED: '60-'66 4X4 Suburban/Carryall Meet 'Earl', '71 C10 Suburban - Sold, but not forgotten... Meet... yet to be named, ‘78 K10 Suburban Daily Driver |
11-17-2019, 09:36 AM | #2 |
Re: ‘78 K10 - Front Axle Not Centered?
wish I had an answer for you but I don't.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
11-17-2019, 12:19 PM | #3 |
on my 81 my front axle sticks out on the driver side. I have looked at a lot 4x4 squares and most of them stick out on one side or the other a little bit. When I had my truck aligned they checked the frame on my truck and it was fine. when I did my cab mounts, I could have moved the body over a bit to make the axle the same on both sides but I would have to move the bed, bumpers etc. I wouldn't worry about it.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 |
11-18-2019, 01:39 PM | #4 |
Thanks, Matt. I’ll see what I can do about not worrying about it. I can be persnickety.
Here’s a good visual.
11-18-2019, 02:03 PM | #5 |
I looked at my 91 and the front axle might be a little bit offset to the right.
Interesting the "square bodies" aren't really all that square if you're trying to figure out something like this There is considerable taper behind the rear door.
Current/past Chevy/GMC trucks: 1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner |
