Old 07-26-2020, 10:15 PM   #551
Captainfab
60-66 Nut
Re: Johns 66
To bolt up the front suspension and related components, I would just go to either Fastenal or a local hardware store and get some grade 8, 7/16 -14 bolts, SAE flat washers and top lock nuts. If you need to know the lengths, let me know and I'll see what I can do.
Old 07-27-2020, 07:29 AM   #552
Johns 66
Johns 66's Avatar
Re: Johns 66
That would be awesome because I dont have the first clue of sizes. Do yoy have an idea of where to get the concave washers rhat fit on the studs of the ulper control arm?
Former Decorated Combat Marine...Semper Fi!!
Instagram jorourke322
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=734699
2019 GMC AT4
Johns 66 is offline   Reply With Quote
Old 07-27-2020, 11:29 AM   #553
SCOTI
SCOTI's Avatar
Re: Johns 66
If you can't find any, I can look through a box of misc hardware from over the years that might have some.
There's also another option.... I've ground the shaft flat in that area so a standard flat spacer can be used. This was during a disc swap & various years of parts were utilized. I don't know exactly what you have but I know there's more than one way to solve the dilemma.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-27-2020, 11:57 AM   #554
Android04
Android04's Avatar
Re: Johns 66
John not sure what all bolts you're needing but a local place here has full front end bolt kits for a littel cheaper then going to the hardware store and they are correct length and tapered.
http://sokyclassics.com/product.php?skcid=1003942
They also have a stainless option and they are really quick at shipping.
Best of luck!
Android04 is offline   Reply With Quote
Old 07-27-2020, 04:07 PM   #555
Johns 66
Johns 66's Avatar
Re: Johns 66
Best of luck!
Ill for sure check them out...I appreciate it alot
2019 GMC AT4
Old 07-28-2020, 11:15 AM   #556
aggie91
I'm just glad to be here!
aggie91's Avatar
Re: Johns 66
John,
Are you looking for item #9 in the attached diagram or the round washer that is flat on one side and concave on the other side that goes against the frame between the frame and the shims (item #8)?
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 07-28-2020, 04:02 PM   #557
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Johns 66
Hi Ed.....Yep these are some that I am missing.
Mainly need the suspension bolts right now...bolts that mount the cradle to the frame, motor mount bolts that mount the pieces to the cradle and frame.
I bought some new u-bolts for the lower control arms.
also needing the concave washers that go on the studs for the upper control arm mounts...I think they may be called camber washers????
Of course will need the bolts that mount the hinges to the doors and truck, bolts for the door striker, windshield wiper motor.
The smaller interior screws I can buy from what Ive seen.
I "Think" that a lot of the chassis bolts are simply grade 8 bolts, Im assuming but don't really know the sizes....got some figuring to do.
Ive been looking for rusted out old wrecked trucks but no luck....Figured the bolts would be good.,
My goal is to get this thing back together, painted or not and then drive it...tired of seeing it in pieces.
Andy and I have been swapping tools in the mail, wire strippers, etc.....and Andy is redoing my instrument cluster for me as well so that's gonna be good.
I also ordered my 5 lug rear axles from CPP and they should be here next week.
Ill get them swapped out and hopefully be able to get some bolts to mount the front cradle so I can make the chassis a roller.
I have bought some Ridler 5 spoke Chrome wheels that will be here next week as well so once I get the chassis stuff back on then I can roll the frame around.
cradle to the frame - Like captainfab said they are grade 8's from the factory, I purchased new ones.
the concave washers - POL has new ones. Or contact Aspen Truck Parts in Arizona for used.
Hinges to doors etc. - I used LMC Truck Parts.
Old 07-28-2020, 05:58 PM   #558
Johns 66
Johns 66's Avatar
Re: Johns 66
Originally Posted by aggie91 View Post
John,
Karl,
The ones I took off were round, if I remember correctly one set had a concave face and one set had a convex set.
Based on the drawing you posted they definitely go ion Bolt #7
2019 GMC AT4
Old 07-28-2020, 06:12 PM   #559
Johns 66
Johns 66's Avatar
Re: Johns 66
Thanks for the info...I looked on the POL website but couldn't seem to find the concave washers....do you happen to have a link
2019 GMC AT4
Old 07-28-2020, 06:20 PM   #560
Johns 66
Johns 66's Avatar
Re: Johns 66
I found this pic of what I am needing....maybe this helps
2019 GMC AT4
Old 07-29-2020, 08:43 AM   #561
The Rocknrod
Moderator
Re: Johns 66
https://www.performanceonline.com/19...-Control-Arms/
Old 07-30-2020, 01:09 PM   #562
Johns 66
Johns 66's Avatar
Re: Johns 66
Thanks my friend...Ill get them ordered for sure.
2019 GMC AT4
Old 07-30-2020, 01:12 PM   #563
Johns 66
Johns 66's Avatar
Re: Johns 66
Well I may not have any bolts to put things back together....but Babe got a new set of shoes today with a lil bling to go with it
2019 GMC AT4
Old 07-30-2020, 01:50 PM   #564
Android04
Android04's Avatar
Re: Johns 66
Looking good.
Old 07-30-2020, 02:41 PM   #565
aggie91
aggie91's Avatar
Re: Johns 66
That is the one I was trying to describe. I have seen them available from somewhere but can't remember where.
I see that Rocknrod found a link to a similar part at POL, looks like those should work.
Karl
The LST Challenge:
Old 07-30-2020, 04:57 PM   #566
bigmoe
bigmoe's Avatar
Re: Johns 66
What size and backspacing did you go with?
bigmoe is offline   Reply With Quote
Old 07-30-2020, 06:51 PM   #567
Johns 66
Johns 66's Avatar
Re: Johns 66
Looking good.
That's the ones ..Im gonna order these tonight
Big Moe..... The rear is 5.5" backspacing, and the fronts are 4.5"
front tires are 245/50/20 and the rears are 275/45/20
2019 GMC AT4
Old 07-30-2020, 07:23 PM   #568
Johns 66
Johns 66's Avatar
Re: Johns 66
The more stuff I do and buy for my truck the more I am amazed at things and how businesses are run...Some you can tell are small businesses and try their best to take care of the customers, some seem like bigger businesses and don't have a clue.
For example....I bought my wheels and tires from a guy in Atlanta, Russ.....I told him what I had as far as vehicle, told him what I wanted and poof....he has them on the way. I paid 1750.00 for Ridler 5 spoke wheels...there were mounted and balanced with a set of lugnuts and were delivered to my door, when they said there were gonna be here...in perfect condition.
Second example is I got my rear axle conversion kits yesterday from CPP....They sent me 4 boxes...and boxes weren't damaged...So I waited until today when I got my wheels to make sure they mated up. Come to find out they sent me an extra kit of axles, drums etc....Of course trying to do the right thing I called them....and after waiting 20 minutes on hold they had no clue that 1. that they sent 2 sets, or 2. how to get them back. I checked my account and I was only charged for 1 set. I asked the guy to send me a call tag and have the extra set picked up....it was like a foreign concept.
Anyways they were the right ones and mate up to the wheels perfectly.....One last thing is that I paid 344.00 with taxes and of course they are made in china.....Im amazed that they can make these, send them on a boat and be cheaper than if it was made here.
2019 GMC AT4
Old 07-30-2020, 10:38 PM   #569
cwcarpenter98
cwcarpenter98's Avatar
Re: Johns 66
Dadgum, those are some fancy wheels! That is pretty weird that they didn't even realize they sent 2 sets for the axles
Christian Carpenter
1963 C10 - Frankentruck 283, 3 speed with overdrive
Overdrive wiring here
1981 C10 - Penny 305, th350
1995 Dodge Dakota Sport
Old 07-30-2020, 10:43 PM   #570
Johns 66
Johns 66's Avatar
Re: Johns 66
Originally Posted by cwcarpenter98 View Post
Dadgum, those iserare some fancy wheels! That is pretty weird that they didn't even realize they sent 2 sets for the axles
Thanks Christian.....yeah I could have kept the extra set and they would have been none the wiser...BUT that isnt the right thing to do.
They eventually did sent me some return labels and Ill get them sent back tomorrow....as they say....Never wrong to do the right thing.
2019 GMC AT4
Old 07-30-2020, 10:51 PM   #571
cwcarpenter98
Re: Johns 66
Exactly, it's always best to do the right thing
Christian Carpenter
Old 08-01-2020, 02:18 PM   #572
Johns 66
Johns 66's Avatar
Re: Johns 66
Welp I have ordered some grade 8 bolts from Wholesalebolts.com...so we will see how that goes.
So I went over to my brother in laws, Randy's shop to check on ole girl.....and didn't like what I saw.....There were about 3 places that the primer had cracked and flaked off...not really sure why...
Im gonna go to a local body shop and see what they say it could be...Im afraid I will have to take it all back down to metal...but would rather do that that have the paint flake off. They sprayed my buddies truck a few years back and did a great job...may see what it cost for them to spray the color, especially after the cracked primer revelation.
Also found a shop to rebuild my rear end and do the axle swap for me.....gonna run me 150.00 but think its worth it...don't want no issues with the rear end......so Ill get it pulled out this week and get that taken care of...And when the bolts arrive the chassis is going back together!!!!!!!
2019 GMC AT4
Old 08-01-2020, 06:31 PM   #573
The Rocknrod
Moderator
Re: Johns 66
I was looking at those wheel. Good job. I recognized the first pic.
Old 08-03-2020, 10:14 AM   #574
aggie91
aggie91's Avatar
Re: Johns 66
I found a set, but they are slightly thicker than the one in the picture. $10 to cover shipping and they are yours if you want them.
Karl
Karl
The LST Challenge:
Old 08-03-2020, 11:04 AM   #575
Johns 66
Johns 66's Avatar
Re: Johns 66
Karl
Karl...Pm me your paypal. I really appreciate it.
Do you happen to have the big washer bolts that go on the inside at the bottom of the front fender?
2019 GMC AT4
