04-30-2020, 11:06 AM | #151 |
Re: Rarest factory paint combos
05-10-2020, 02:00 PM | #152 |
Was it this off white (526) that was used on the two toned trucks both Chev and GMC 64-66?
1953 3100 261cu in, sm420, 3.55 torque tube, omaha orange 1964 GMC 1000 series,custom, 305E, sm420 |
05-10-2020, 08:37 PM | #153 |
Yes, 526 was the roof color for two tone coded trucks. 521 white was available as a solid body color only. Also note that the bumpers, grille (if not stainless), grille surround, trim insert, and hub caps (if not bright) were all off-white also - unless the truck was solid 521 white, in which case all of the above areas were also 521 white. Tailgate letters were off-white 526 except on a 521 or 526 (solid) truck, in which case the letters were black.
05-10-2020, 11:08 PM | #154 |
Perfect info, thank you Jocko.
01-20-2021, 08:12 PM | #155 |
I solved the mystery of the rare paint color Seamist Jade Metallic that I am planning on painting my truck after staring at the tailgate I picked up ages ago as a replacement for my original. I found a touch paint place online that has an incredible catalog of paint codes. It cost about $35 including shipping which was well worth the cost. Here's what I got. I had this heater top that was primered a medium gray. The lighter pics are in direct sunlight and the others are off to angles. I think it will look great on my truck.
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. |
01-20-2021, 11:29 PM | #156 | |
Christian Carpenter 1963 C10 - Frankentruck 283, 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
01-22-2021, 09:25 PM | #157 |
This is where I got the paint. Very good service.
https://www.paintscratch.com/cgi-bin/select-color.cgi
01-23-2021, 12:21 AM | #158 | |
12-13-2021, 01:47 PM | #159 |
12-13-2021, 11:38 PM | #160 | |
Junior Member
Randy |
12-14-2021, 12:35 PM | #161 | |
It looks similar to the paint on this Chevy too.
Keith SOLD - 1963 C10 Short Fleet 350/700R4 4/6 drop 1967 GMC Super Custom - Short Fleet COPO concept w/427 BBC T-400 w/Doug Nash overdrive 4/6 Drop, Buddy Buckets, etc... Frame Off (In Progress) I call it "Vulgar Display of Power" 1980 Silverado Original paint 49k Original miles 4/6 drop Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941 |
