Old 01-08-2014, 09:35 PM   #1
Culchie
New user with questions
Recently bought a 1978 K10 from a guy who didn't know much about it. It has a 1992? 350 engine with a Rochester instead of the TBI, It idles kind of rough but smoothes out above 2000 rpm. Im running 33s and can spin the tires in the dry with no problem. Question is, and anyones guess is appreciated, do you think its been regeared? what about a cam (as far as the idle)? the transfer case is a NP 241c so Im assuming the trans is a 700? Any guesses?
Culchie is offline   Reply With Quote
Old 01-09-2014, 10:10 AM   #2
tlawre87
tlawre87's Avatar
Re: New user with questions
Can't help much on the cam. For the transmission crawl under it and look at the pan.
For the rear end, jack it up. The number of driveshaft revolutions to spin the tire will give you a rough idea of your rearend gear.
(ie a little over 4 turns would be a 4.10)
This guide should help.
Trevor
74 C20...work in progress.
04 Saturn Ion...Daily Driver
tlawre87 is offline   Reply With Quote
Old 01-09-2014, 11:11 AM   #3
russellh575
russellh575's Avatar
My 80 C10 has a pretty decent cam in it and there is a noticeable difference in the way runs once it gets past 1500 rpm, so I guess the cam could be what is making run like that.
russellh575 is offline   Reply With Quote
Old 01-10-2014, 09:09 AM   #4
Wade2ride
It's always good to Check your timing also. If the timing is off it can give you a rough idle.
There's no point in buying new.
1977 K20, Full time 4x4 (Engine Blown/Project)
1985 Buick LeSabre
2003 Kawasaki Vulcan 800
2003 CBR 600RR
Wade2ride is offline   Reply With Quote
gears, idle, k10, transfer case
