05-03-2024, 01:48 AM | #1 |
Location: 3,018 feet above the SoCal/Mojave Desert region.
About how much coolant in a 350 block?
I drained the radiator but how much is still in the engine? Trying to get as close to a 50/50 coolant ratio. Thanks.
05-03-2024, 07:12 AM | #2 |
Re: About how much coolant in a 350 block?
I don't remember the exact measurement, but I always put in 2 gal antifreeze, then top off withe water and it always seems to give m e the correct mixture on the little measuring device thing.
05-03-2024, 09:52 AM | #3 |
Junior Member
Set up a catch pan and remove either plug from the bottom of the block to drain all of it. Then you'll know how much is in the block, and have a precise ratio.
05-03-2024, 04:29 PM | #4 |
Better chance of flushing all the boogers, too
1970 C10 Custom longbed 350/350 |
05-03-2024, 07:35 PM | #5 |
My BBC and 4 core takes maybe 4 gallons of premix, I'd buy five anyway. I used to mix my own with distilled, 50/50, but the premix I use is probably better stuff, IMO. I think the entire system approaches six ga.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s details such as OEM identifications& part numbers, written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
05-03-2024, 10:45 PM | #6 |
20' Daredevil (Ret)
That's what I do as well. I believe the total capacity with a 350 is right at 4 gallons. I put in 2 gallons antifreeze and add water until full, ending up with a 50/50 mix.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
05-03-2024, 11:12 PM | #7 |
Who Changed This?
I went looking for cooling system capacity, but got bored looking through the 671 page repair manual. I've always flushed the system with water and then put in 2 gallons of antifreeze, finishing off with water, just like Palf70step and Stocker have said. Pretty sure that the system is close enough to 4 gallons that unless you live in the frozen north, you'll be close enough for freezing protection.
