06-03-2015, 01:18 AM | #4 | |
60-66 Nut
Re: 63 3/4ton control arm swap
I honestly don't know about the V6 engine mounts as I have not had any experience with those other than removing them. Yes I have seen/heard that the crossmember can be changed with the engine in place, but it just seems much more difficult that just pulling the engine and having the room you need to do the job correctly. Of course to me, pulling an engine in one of these older trucks is quite simple and can be done in a few hours.
Changing the crossmember does not change the geometry in a lowered stands. What changing the crossmember does, is allow you to use a lower control arm other than a stock '63-'66 C20 lower control arm. Which is what I thought your goal was. Yes there are dropped spindles for the C20's, but as far as I know you will be stuck with an 8 lug wheel. Also I do not know if there is a dropped spindle that will accept the '63-'66 C20 lower ball joint. That would be something to check with a spindle manufacturer or seller about. The one and only C20 that I was involved with in converting to a C10, we changed the entire front suspension, including the crossmember. Quote:
Tags |
3/4 ton, control arms, crossmember, disc brake conversion |
