05-28-2020, 08:40 PM | #1 |
Lokar cable linkage and 4L80? Header and column shift options?
I was ready to order headers and the Lokar cable linkage for column shift clearance but I see in the instructions it says it won’t work with 4L60 or 4L80 so I’m back to the drawing board. Any other options to run medium or long tube headers and a column shift?
05-28-2020, 11:38 PM | #2 |
Re: Lokar cable linkage and 4L80? Header and column shift options?
I run the Lokar column cable shift with a 4L60e. I don't see why it wouldn't run with headers either. The mechanical rod linkage setup for Lokar may not but I'm not sure on that.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold 1972 C10 5.3L/4L60E 12bolt 5Lug - Sold 1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!! 1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold 1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold 1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold) 2003 K2500HD 8.1/Allison1000/NP263 |
05-29-2020, 08:36 AM | #3 |
Check with KOOKSHEADERS.com they helped me out on a set for my small block with the angle plug heads I bought. good quality and you get what you pay for.
05-29-2020, 09:14 AM | #4 |
Almost Satisfied
I'm running the long tube Speed Engineering headers and using the Lokar solid linkage. Works perfectly on my 4L80e. I know some have had to bend the shaft some to make it work. You can see pics in my build thread.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
05-29-2020, 05:16 PM | #5 |
05-29-2020, 06:31 PM | #6 |
I could not even get the Lokar cable shift to work well with my column shift and a 2004r trans. PM me if you are interested in it.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
Thread Tools | |
Display Modes | |
