05-29-2020, 11:39 PM | #1 |
Lock-tite or no...
Working on installing my new clutch fan. Looked and found the threaded studs for the water pump flange that seem the best fit. They thread just slightly through the holes leaving a few of the fine threads that will be covered by the pulley. Question I have is whether to screw them in with thread locker or not.
In the one pic the coarse threads look buggered up , but they actually just have a little grease residue on them that needs wiped off. Thank you! Ned
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
05-29-2020, 11:43 PM | #2 |
Re: Lock-tite or no...
I have never used lock tite on fan bolts
05-30-2020, 12:00 AM | #3 |
Yes.
You could Loctite the studs in the pump before installing the fan. This will prevent the studs from rubbing the water pump casting. .
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
05-30-2020, 12:32 AM | #4 |
20' Daredevil (Ret)
Just not red, though..... right?
05-30-2020, 12:42 AM | #5 |
Thanks for the advice guys!
05-30-2020, 08:14 AM | #6 |
Blue Loctite would be the best in this application.
05-30-2020, 09:08 AM | #7 |
X2 on blue
05-30-2020, 09:29 AM | #8 |
I have never locktighted those studs. Zero issues.
05-30-2020, 12:20 PM | #9 |
Ned you have the wrong studs for the clutch fan. You need Dorman products 675-001. I bought mine from Auto Zone, gave them the number and they ordered them for me. The fine thread portion of the stud is shorter and won't run into the water pump. Auto Zone sent me ten by mistake so if you can wait till I can ship them to you I'll be happy to send you four. PM me your address info and I'll get em in the mail Mon. Phil
Phil "Money is only a tool to create and achieve what you want most in life" PayPal: rodnrudy@comcast.net |
05-30-2020, 04:42 PM | #10 | |
05-30-2020, 06:47 PM | #11 |
Not a problem. I like that I could help a member in need. They'll be in the mail Mon.
