01-24-2020, 12:39 AM | #76 | ||
Re: Bring back the stick shift
Sadly I was also reminded that I was the one who was backing it out of the garage one day, looking over my shoulder and almost put it through the kitchen wall. I mean I came within 2" -3" of the wall kinda close. Any other manual trans - no problem. Those damned Vee Dubs with their push down, out and do the Hokey Pokey to get reverse! Forget it! I'll put my foot out the door and push it backwards! I think she likes her '60 for the same reason I like my truck!
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
01-24-2020, 02:28 AM | #77 |
Back when I was young and beer was more important than a battery my stick shift got me started many times. Had to park on a hill and hope nobody parked in front of me.
01-24-2020, 10:29 AM | #78 |
Some people just have no clue how to listen to an engine.
They have to be told to shift at X and Y speeds and cannot understand how that might vary according to conditions and that you can shift just fine without a speedometer. Or a tach, but that would be like trying to teach rocket science to a gerbil.
Current/past Chevy/GMC trucks: 1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner |
01-24-2020, 11:56 AM | #79 |
It seems I have come full circle.
01-24-2020, 12:06 PM | #80 |
My dad bought a brand new C10 in 1969. 350 automatic, the first V8, automatic truck he had ever owned.
When the first snow came I got in his new truck and took off down the hill from the house. The fast idle was still set when I came to the steep little section of road at the T. I hit the brakes and the front wheels locked but the back were still pushing. I could see my life flash in front of my eyes. If the crash didn't kill me my dad would.Then I gathered my wits, and kicked it into neutral. I can credit that bit of wisdom to the fact that I lived to tell the story.
01-24-2020, 04:47 PM | #81 |
These days, getting rid of the used beer may be the most important
01-24-2020, 06:03 PM | #82 | |
01-24-2020, 07:48 PM | #83 | |
This is not a cut and dried subject for me. (Unless you try to make me drive a Ford). An important part of the equation is maintenance, some of It is luck and then perception. I had a 2003 Dodge Cummins HO six speed, with a chip. Can you say hot rod? I loved that thing until the injector pump started giving trouble. Then the 05 Duramax. I love that truck, and it is what I drive most. That said, it blew a head gasket at 98,000 miles. The factory warrantied it and installed a new head. I will keep driving my Duramax most of the time, but I admit the Cummins is hard to beat.
01-24-2020, 08:24 PM | #84 |
$80K ?????????????
That's not a lot less than what we paid for a house and 40 acres, 17 yrs ago.
01-24-2020, 08:25 PM | #85 | |
1959 GMC 100 3 on the tree 270. 1968 GMC k2500 Stepside 1972 Chevy Monte Carlo Custom. |
01-24-2020, 08:50 PM | #86 |
01-24-2020, 09:20 PM | #87 |
All can say is there's a lot more to a good truck than the motor. Like how about transmissions or the rest of the truck? A truck that goes through transmissions is a p.o.s. as much as one that goes through engines. But wait, the '01 Duramaxes didn't go through engines, that was the Fords after they stepped away from the 7.3 (which was and still is an excellent motor. The first D-max had fuel rail issues. I got 335k out of my '92 6.5TD GMC and it weighed over 8k minimum. I used the heck out of that truck for 22 years. That does not define a P.OS. I made over a million dollars out of that $20,500 truck. In ordered that one with a 5spd
01-24-2020, 10:57 PM | #88 | |
I know the pieces fit
01-24-2020, 11:27 PM | #89 |
laying low
Yeah that Ford diesel issue was if the heads had to come off the procedure was to raise the body off the chassis to gain clearance to remove the heads. I believe the shop rate allowed something like 8.5 hours to do the job. Not something you'd want to attempt at home. My nephew did a few of those.
01-25-2020, 08:51 AM | #90 |
That Ford was the 6.0. Sadly it had a good life in medium duties before Ford hot roded it. It also had other issues besides head gaskets.
Chevy and dodge used the same basic CP3 unit for diesel injection. Early duramax did t have a lift pump though. The big issue wasn't the pumps but injectors as they kept raising I jection pressures for emissions. This was causing injector bodies to crack and was fixed with new stainless injector bodies. Injection pressures raising 4 times also caused a sand blasting effect to the nozzles. Last I heard injection pressures was up to 30k psi |
01-25-2020, 11:46 AM | #91 | |
The fiber optic construction company had a bunch of Silverados and Sierras. I was somewhat amazed at how they beat on them, driving through the sagebrush and off of nearly cliffs.
01-25-2020, 12:10 PM | #92 |
Hey guys, I know I participated, but this is a stick shift thread, not a diesel thread.
The Ram (Dodge) we are taking to auction has 296,000 miles on it. It was turned over to pipe line crew when new, and has never had any respect. That thing has been abused every day of it's life and kept on ticking. Now, the input shaft bearing is worn out. We thought about fixing it, but, we are selling it, because nobody seems to be able to drive it. Of course we have a couple of guys that know these trucks, but the majority of people now days can't drive a stick shift. I may have mentioned it here, and, Some of you know we had a truck stolen a while back. It was a stick shift, so I guess somebody still likes them.
