Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > General Discussion
Old 04-16-2024, 03:58 PM   #1
GOPAPA
"Tail Gate Best Seat In House"
GOPAPA's Avatar
Can you put to much oil in compressor
and ruin anything ,,,,I lowned my compressor last fall to a neighbor to blow out his srinkler system and ever since he brought it back it has been leaking oil down the side of the tank and onto the floor ,, I ask him if he added oil and he said he did.
When you learn a thing a day you store up smart.
GOPAPA is offline   Reply With Quote
Old 04-16-2024, 04:16 PM   #2
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: Can you put to much oil in compressor
If it has a sump for oil, it certainly can be overfilled. Doing this could lead to aeration of the oil and lack of proper lubrication. Does it have a drain plug?
~Steven
Simi Valley, CA
Old 04-16-2024, 06:01 PM   #3
Dead Parrot
Mine has a sight glass and marks for proper level. If no glass, maybe there is a plug on the side that you fill until it starts leaking out, similar to a lot of differentials.
If you have a manual for the thing, check what type of oil it uses. Mine recommends a special compressor oil. Bad news is that oil was about $20/qt. Good news is a total change used less then half the quart. Based on the manual's recommendation of changing every 100 hours of running, I should be good for many more years.
Dead Parrot is offline   Reply With Quote
Old 04-16-2024, 06:34 PM   #4
GOPAPA
GOPAPA's Avatar
I called the neighbor about what oil he put in the compressor oil filler and he said it was a compressor oil and he still has the bottle with some still in it and I can have it ,, I will go get it tonight and take photos of it and the filler on the compressor for you guys that have responded to my conserns about my compressror,, thanks to you guys.
Old 04-16-2024, 06:59 PM   #5
GOPAPA
GOPAPA's Avatar
neighbor came over with the oil bottle he used
Old 04-16-2024, 07:08 PM   #6
72c20customcamper
72c20customcamper's Avatar
The oil should be at the top of the dot little under or over isnt a big deal . But it looks like it’s way over filled
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 04-16-2024, 08:19 PM   #7
truckster
truckster's Avatar
If you're lucky you'll get away with draining the excess oil. Hopefully it hasn't blown out a seal.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 04-16-2024, 08:52 PM   #8
GOPAPA
GOPAPA's Avatar
I think it has blown out a seal as it leaks very slowly on the floor of the garage where I store it at for some time now ,,.. what are the steps to replace a seal may I ask.. I do not have a book with with schematics.
Old 04-16-2024, 09:24 PM   #9
RustyPile
RustyPile's Avatar
Crankshaft and its seals are located above the NORMAL oil level and cannot leak when not running. Have you drained the oil and replaced it with the proper amount.. The proper amount is right there on the label -- Do that first, and if the compressor still leaks, determine where it's leaking from.. If it ain't broke, never work on it until it is.
RustyPile is offline   Reply With Quote
Old 04-16-2024, 09:54 PM   #10
Steeveedee
Who Changed This?
Steeveedee's Avatar
^ What he said. Plus look to see if he tipped it over, dragging it around.
~Steven
Simi Valley, CA
Old 04-16-2024, 10:19 PM   #11
farmall
farmall's Avatar
The question is where is it leaking from?
One used to be able to find Detroit Diesel 2 Stroke SAE 30 non detergent everywhere. Now its just in coastal marine areas.
1955 GMC 250 8 Flatbed
1971 C30 157" 350 4spd 10' Flatbed
81 GMC K30 CnC 9' Flatbed 454 T400
89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958
71 LT1 Convertible, 72 Coupe
69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2
farmall is offline   Reply With Quote
Old 04-16-2024, 11:54 PM   #12
Dead Parrot
2nd the drain and refill with proper amount before getting too concerned about leaks. That shaft seal is probably well above the "full" level on the glass. Can't leak much just sitting there if the oil level is correct.
Even if it keeps leaking, unless it is a lot, a small pan full of that spill pickup stuff will last a long time.
Walmart around here still sells non detergent 30w. Its not the Detroit Diesel stuff but still good for filling your generic oil cans.
