02-01-2020, 09:07 PM | #2076 |
A guy with a truck
Re: How to: Ruin a perfectly good C10
Put in some time today getting the trans in its final resting place. The mount sits about 3.5” higher than before the dropmember, so to keep from stacking up a bunch of spacers, I cut the crossmember tab off and welded a 1.75” spacer to it. I cut holes to recess the mount bolts—one less thing to drag the speedbumps.
Once mounted, the trans ended up coming into the cab more than I wanted, but the driveline angles are good and everything is clearing. Fluid is filled and shifter is in, now I just need to build a driveshaft tunnel, which is wanting to occupy the same space as my bench seat. I think I’ll rename this truck “5-pound sack”.
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 02-01-2020 at 09:24 PM. |
02-02-2020, 07:53 PM | #2077 |
A guy with a truck
The old girl got some sun today:
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
02-02-2020, 07:58 PM | #2078 |
A guy with a truck
02-02-2020, 08:06 PM | #2079 |
A guy with a truck
02-02-2020, 09:22 PM | #2081 |
A guy with a truck
Thanks man. Magnaflows are hanging off the end of the collectors as a temporary exhaust. Hopefully it will maintain some of that aggressiveness once the pipes are run all the way out the back.
Bedtime for blue...
02-02-2020, 09:37 PM | #2082 |
Slice n dice... So what is your actual ride height at the front cab mount ?
Beautiful stance. |
02-02-2020, 10:14 PM | #2083 |
A guy with a truck
Thanks, pretty happy with how she sits. There’s right at 4” under the front, 4.75” under the rear cab mount, since I like a little ‘hotrod rake’.
02-02-2020, 10:28 PM | #2084 |
Lookin gooooood!
02-03-2020, 11:17 AM | #2085 |
I have to agree with SCOTI, lookin real gooood!
How are you liking the new trans? Any concerns or adjustments needed or is it perfect straight out da crate shiftin like butta?
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
02-03-2020, 08:33 PM | #2086 |
A guy with a truck
Thanks Scoti!
Thanks, seems to be good so far. I haven’t had an opportunity to truly test it, but beating on it a little around the neighborhood, I’m very happy with it. Definitely needs a shorter lever, though...
02-04-2020, 12:30 PM | #2087 |
Just went through the entire thread! WOW great work. I'm just starting my build. This has given me so many ideas my wallet is gonna hurt! Wife says thanks!! lol
02-04-2020, 08:42 PM | #2088 |
A guy with a truck
Haha, you’re welcome. If not for this forum, my truck would look entirely different than it does now, and not in a good way. Just paying it forward
02-04-2020, 10:06 PM | #2089 | |
Gringo your truck is sounding good, sitting good, and rolling good. Thanks for giving back man.
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444 "It's only money". |
02-05-2020, 10:11 AM | #2090 |
Almost Satisfied
I'm glad you didn't crush that beer...with the bumper. Truck looks and sounds great.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
02-05-2020, 07:43 PM | #2091 |
Sounds great and looks great!
I can't wait to be shifting thru the gears in mine. I did a mid-shift conversion on mine, and just by feel (on the bench) the shifter throws are a bit shorter than in the rear position. Maybe so you can have a longer lever and not end up with a huge throw.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
02-06-2020, 03:05 PM | #2092 | |||
A guy with a truck
02-06-2020, 11:32 PM | #2093 |
A guy with a truck
New shift lever installed, much better. It’s 6” shorter, bent back toward the seat, and over toward the driver. Throw is waaay better than before and falls right in my hand
02-07-2020, 11:06 PM | #2094 |
So all this time has gone by, how do you like your radio? And do you have courtesy lights installed in foot wells? If so whatcha got?
02-08-2020, 11:10 AM | #2095 |
A guy with a truck
Unknown. It looks nice enough, and installed relatively easily, though I did modify it to suit my personal desire to have the knobs closer to the dash. As far as sound, I don’t think I’ll know for a while, it is very low on the list of priorities, heck, the only wiring in the truck right now is the bare minimum needed to run the engine. Same for footwell lighting, but if I do it will undoubtedly be a factory-type setup.
02-15-2020, 08:56 PM | #2096 |
A guy with a truck
Made a change to the engine setup. I found a screaming deal on this FAST 4-bbl throttle body, which uses all GM sensors, making it plug-and-play with the Holley Terminator-X. It did take a little bit of playing with the tune to get the idle to cooperate, but overall I am match happier with this setup versus the 90mm stock-style. Bonus: the throttle cable and air cleaner fit just as they would with a carb, which is to say without (much) modification
The air cleaner needs paint and I think I’ve changed my mind (again) about the oil fill and knock sensor placement. They are an eyesore and must be eliminated...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 02-16-2020 at 12:10 PM. |
02-17-2020, 11:26 AM | #2097 |
Looking good Chris! I'm liking the direction you're headed with the new look of the engine! And every time I see your truck, it makes me want to go drive Brutus, and stab a T56 into my GTO!
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
03-06-2020, 03:18 AM | #2098 |
Wow, I've missed a lot. For some reason, I'm not getting emails from this forum anymore.
What's the number on the new stick?
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
03-06-2020, 01:52 PM | #2099 |
Yeah me too man, then I found out you have to pay money for the email alerts! lol.
03-06-2020, 09:54 PM | #2100 | ||
A guy with a truck
Well, dang...
