Old 12-25-2009, 01:26 PM   #1
GMC3
06 w/ 5.3 burning oil?
My 06 silverado w/ the 5.3 and 42000 miles is now burning a quart of oil every 1500 miles. I did some online research and i found that this is not uncommon and chevy has a service bulletin on it. Does anyone have any experience with this? Has anyone seen the service bulletin? or know what the problem is?
GMC3 is offline   Reply With Quote
Old 12-25-2009, 02:17 PM   #2
GMC3
Re: 06 w/ 5.3 burning oil?
oh yeah. forgot to add that i change my oil and filter every 3000. used conventional up to the 36000 mark and never had to add between changes even though it did burn a little but was still in range on the dipstick. switched to mobil 1 syn. at 36000 and have had to add oil between oil changes
Old 12-25-2009, 02:49 PM   #3
truckdude239
truckdude239's Avatar
according to teh tsb it is caused by a nick in a vavle stem
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 12-25-2009, 02:50 PM   #4
Thealien
Thealien's Avatar
Even though I am a fan of synthetics I would try switching back to what you were using and see if it goes back to burning just a "little"
Old 12-25-2009, 03:20 PM   #5
msgross
msgross's Avatar
ouch, if mine started doing that i'd be looking to trade it in...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 12-30-2009, 07:31 PM   #6
GMC3
Had the mechanic at work print out the service bulletin for me and like truckdude239 said it is caused by a nick in one or more of the valve stems, is common in low mileage vehicles, and the recommended repair is to replace the cylinder heads. i bought my truck before the 5 yr. 100,000 powertrain so it looks like this one is on me. This is my first chevy, and have been pretty disappointed. I want my 91 f150 and 24,000 dollars back
Old 12-30-2009, 08:12 PM   #7
truckdude239
i'd still call the dealer and ask them if there is something they can do for you
David fuller
2000 Tahoe 5.3l 378
Old 12-30-2009, 09:20 PM   #8
msgross
msgross's Avatar
I agree, they have special conditions sometimes and cover things just slightly out of warranty..
The Garage:
Old 12-30-2009, 10:04 PM   #9
67ChevyRedneck
67ChevyRedneck's Avatar
You also haven't definitely found the problem yet.
You're 100% sure there's no leak?
Are you doing any heavy towing or a lot of 4wd use? That will cause oil consumption to increase.
Also check for a plugged PCV. I think your truck should have the fixed orifice one. It's at the back of the valve cover on the driver's side. When you pull it, it should have just a small hole drilled in it. If not, if it's the one with the check ball, you may want to replace it with the "fixed orifice" one. My 2000 did the same thing a few years ago, she was going through almost a quart every 1000 miles, I put the fixed orifice PCV in it and it uses maybe an 1/8 quart between 5,000 mile Mobil One changes. What I have mentioned is also a TSB too, but like I said, I think GM put the fixed orifice in the later 5.3's BUT without knowing, you or someone may have replaced it without knowing it doesn't need to be changed.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 01-02-2010, 09:55 PM   #10
67ChevyRedneck
Did my suggestion help? Any updates?
Jesse James
Project "On a Dime"
Old 01-03-2010, 11:44 AM   #11
GMC3
i appreciate the suggestion. will be checking my pcv today. I really hope that helps. don't want to take apart the top end to do my cylinder heads. i'll get back to you. thank you
Old 01-03-2010, 02:18 PM   #12
GMC3
looked into my pcv valve and apparently its not meant to be replaced. its not in a rubber grommet like most, it appears pressed into my valve cover. and while i was at the local auto parts store i looked up the replacement part and it said N/R meaning "not required". i guess it is the fixed orifice type, and they are not supposed to go bad. Does anyone know if they do go bad anyway? and to get back to you, i really don't drive my truck hard. I hardly tow anything and use the 4wd occasionally. thank you and i really appreciate the help and responses.
Old 01-03-2010, 03:42 PM   #13
67ChevyRedneck
My 2000 has a rubber grommet that the PCV goes into and it comes out pretty easy, so it must be the fixed orifice type. No, there's no way that they can "go bad" that I know of. It's just an empty PVC with a small hole drilled in it. My 99 S-10 doesn't have a replacable PCV either.
Jesse James
Project "On a Dime"
Old 01-05-2010, 08:19 PM   #14
Primed67
Primed67's Avatar
My 07 has the same issue. burns roughly a quart of oil every oil change. all i go is hwy driving. I'm going to look at the PCV valve and see if that's the issue. good post guys. Thanks!
1969 Chevrolet SWB Stepside
1959 Chevrolet apache * Sold
1967 Prostreet Chevy SWB Fleetside *Sold
2014 1/2 ton Crew Cab Chevrolet 4x4
Primed67 is offline   Reply With Quote
Old 01-05-2010, 09:03 PM   #15
bobbo
Droppin' It Like It's Hot!
bobbo's Avatar
There is also a problem with the oil rings being bad. Just had an 08 Tahoe with the 5.3 in at work a couple weeks ago that had to have new pistons and rings installed to cure the oil consumption problem. Very low miles on it. May look into that.
Robert
Life Member
RIP CAROL JANICE HARTMAN. BELOVED MOTHER. 01/04/53 - 03/05/09
1969 1500
Norwood, MO 2007
Big Sandy, TN 2008 Had nothing to do with the forklift!
Kirkwood, MO (Midwest Meet 2009)
Midwest All Truck Nationals, KCMO - 2008 - 2009 - 2010 - 2012 - 2014
SUPPORT THE SITE HERE!
bobbo is offline   Reply With Quote
Old 01-09-2010, 10:45 AM   #16
Manbearpig
Manbearpig's Avatar
Put a catch can on the PCV like this:
http://wiki.ls1tech.com/forums/gener...can-setup.html
1972 GMC C10
Manbearpig is offline   Reply With Quote
