Old 10-16-2017, 12:01 PM   #1
Never enough
Never enough's Avatar
Difference in high hump hole location ??
I am looking at getting a hump to convert my 1969 C10 auto to 4 speed but came upon 2 different hole locations. What is the difference in application for these ?
1969 Chev C10
1989 Chev R3500
Never enough is offline   Reply With Quote
Old 10-16-2017, 12:12 PM   #2
Keystone_Hate
Re: Difference in high hump hole location ??
I believe it depends on the location in which the engine is mounted. If it's a small block, there are two different mounting locations for the engine. The forward mounting being the stock location for 2wd. The rear mounting location being stock for 4x4. This would dictate how far front or back your trans will be, which determines where your shifter will come through the hump. Make sense?
Edit: Also if you have an inline six it will be mounted in the rear position so you will need the hump with the hole further back.
Keystone_Hate is offline   Reply With Quote
Old 10-16-2017, 01:43 PM   #3
Never enough
Well, the inline 6 theory makes more sense for this particular hump, since there is no second hole for a transfer case shifter.
Guess I'll stick with the forward hole cover and hope it lines up on the '89 chassis with bb and 5 speed.
1969 Chev C10
1989 Chev R3500
Old 10-21-2017, 09:37 AM   #4
Don Quixote
Don Quixote's Avatar
Do you happen to still have the doghouse with the rear hole? I need one for my 292/465.
Rocinante: 1972 GMC C25, 292, SM465, 14 bolt, power nothing, 440k and still handles my PCS moves
Jorge: Kia Roller-skate with lots of buttons for the wife
Wovoka: 2017 Indian Chief Vintage, better on gas but not much
So far, this is the oldest I've ever been.
Don Quixote is offline   Reply With Quote
Old 10-24-2017, 04:01 PM   #5
Bob B.
My V-6 GMC has the rear hole, and it's a 4X2. Having the New Process 435 transmission might make a difference too.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is offline   Reply With Quote
Old 10-24-2017, 04:34 PM   #6
irl104
Mine is a 68 and has a 292 with a new process four speed transmission and takes the one in the second picture, which the hole is further back on the high hump.
irl104 is offline   Reply With Quote
Old 10-25-2017, 09:24 AM   #7
Mike C
Mike C's Avatar
All 3 engine families (maybe 4 with GMC V6) have the motor in a different location. The big block is the most furthest forward which is probably the first pic you have, then the small block in the 2nd pic.
4 wheel drives obviously have 2 holes for manual trans and one for autos.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 10-25-2017, 09:55 AM   #8
CrewCab59
CrewCab59's Avatar
If you need pics, I can post up both of my C/30 cab chassis 350/4spd and 292/4spd.
1972 Custom Deluxe 20 4x4 burb
1971 GMC SWB CST 4x4
1972 GMC k20 4x4 (X- brush truck )
1971 Chevy CST Blazer 4x4
1971 Chevy C/10
1970 Cab Chassis C30 157"
1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica )
1988 Chevy V30 4x4 wrecker challenger 4812
CrewCab59 is offline   Reply With Quote
