Old 10-13-2008, 06:54 PM   #1
crm318
Alright Alright Alright
crm318's Avatar
carb is loading up on me
i just installed a a quadrajet that i just rebuilt and im having an extremely rich condition, the truck ran fine in town and then i took it for a 30 mile highway drive which was also good. when i got off the highway and into town, i noticed that the truck began to bog and smoke a bit at idle, it was ok if i kept the rpms up. i disassembled it and everything checked out. there was also no debris in the bowl or needle/seat area. i bent the float to lower it and put everything back together. it still has the same symptoms. i did notice that the little tiny clip for the needle to hang on the float was missing. is that a big deal? i have heard of many guys running without them. what other things could cause this flooding?
1972 Cheyenne
Chevrolet red and white
357ci, Vortec heads,
GM Performance high rise intake,
Comp 268H .454/.454 218/218 110 LSA
Quadrajet carb, Flowtech headers, 2.25 40 series
HEI, Curve kit, TH 350, 3.07 gears
275/60/15s on 15x8 rallies
crm318 is offline   Reply With Quote
Old 10-14-2008, 02:04 PM   #2
crm318
crm318's Avatar
Re: carb is loading up on me
anyone?
1972 Cheyenne
Old 10-14-2008, 02:22 PM   #3
77 350 Shorty Wide
77 350 Shorty Wide's Avatar
It's possible the new needle & seat are defective. You did install a new one didn't you? Fuel pump pressure is to high. Something stuck in the needle and seat. Are your idle screw adjustments right? Lot's of places to look. Good lick & God Bless, Terry
Sorry just saw you looked for debris in the seat.
77 350 Shorty Wide is offline   Reply With Quote
Old 10-14-2008, 04:23 PM   #4
crm318
crm318's Avatar
i guess ill have a look at the idle screws. ill let ya know.
1972 Cheyenne
Old 10-16-2008, 04:07 PM   #5
Myself
I have heard older Quadrajets like to leak out of the soft plugs on the bottom side of the carb.
Myself is offline   Reply With Quote
Old 10-16-2008, 07:47 PM   #6
crm318
crm318's Avatar
i have mine apoxyed.
1972 Cheyenne
Old 10-16-2008, 10:17 PM   #7
primered_junk
ASE master tech/machinist
primered_junk's Avatar
Fuel pressure is a big deal on q-jets, they don't like it. Also check the bushings in the throttle plate, if they wear it turns into a vacuum leak. Check for vacuum leaks as they could cause a rich idle (belive it or not) Check the choke pull off and make sure the "flap" is not falling closed, and also make sure the "butterflies" on the secondarys are binding and hanging slightly open.
"I sit here and I pray in my broken down Chevrolet....."
primered_junk is offline   Reply With Quote
