Old 02-15-2019, 06:18 PM   #1
Dachshund
1947 Guages
I am switching over to 12v and, of course, the gauges are still 6v units. What is better/cheaper - replace the whole cluster, or get individual gauges? The chrome on mine is pitted, but I was planning on painting them anyway, so it's not a big deal. All I need are the Amp and the fuel guage, correct?
Dachshund is offline   Reply With Quote
Old 02-15-2019, 11:14 PM   #2
Jesse Z
Re: 1947 Guages
Amp guage doesnt need to be changed, does it?, oil pressure and temp are mechanical,. So I think your looking at fuel gauge only. 12v replacement fuel gauges are chaep
Dont foreget to change light bulbs.
Jesse Z is offline   Reply With Quote
Old 02-16-2019, 11:23 AM   #3
e015475
e015475's Avatar
Re: 1947 Guages
The bezel and glass are easy to replace too. Parts are available from the usual suppliers.
e015475 is offline   Reply With Quote
Old 02-16-2019, 11:58 AM   #4
MARTINSR
MARTINSR's Avatar
Re: 1947 Guages
As I remember I didn't even change the fuel gauge. I don't think it works on "volts" so it doesn't matter.
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 02-16-2019, 01:21 PM   #5
Dachshund
Re: 1947 Guages
Ok, thanks! Another Question -
What is the black sealant stuff used under the glass? It (WAS) it a gasket, or some sort of caulk?
Old 02-16-2019, 05:04 PM   #6
mr48chev
mr48chev's Avatar
Re: 1947 Guages
I think that most of the truck trinket vendors have guage parts availble but this was easy for me to bring up.
https://www.classicparts.com/Gauge-Parts/products/851/
I'm thinking that "sealer" may originally have been the Bezel gasket.
My ongoing truck projects:
Old 02-16-2019, 09:55 PM   #7
Dachshund
Re: 1947 Guages
Ok - Thanks! Now - are there TWO in each cluster (one on each side of the glass)?
Old 02-17-2019, 04:14 AM   #8
MiraclePieCo
MiraclePieCo's Avatar
Re: 1947 Guages
Brian
Classic Parts sells 6 and 12 volt gas gauges, so maybe there's a difference?
Yikes, they are NOT cheap:
https://www.classicparts.com/searchprods.asp
1951 Chevy Panel Truck
MiraclePieCo is offline   Reply With Quote
Old 02-17-2019, 03:03 PM   #9
weim55
Re: 1947 Guages
If you are converting to 12 V on an otherwise stock truck you should be OK through the factory Ammeter. But if you have added a significant amount of electrical Accessories ( Electric fans, air conditioning, high-end stereo, etc) as well as a high output alternator the original wiring will not handle the The high amperage running through it.
Steve weim55 Colorado
weim55 is offline   Reply With Quote
Old 02-17-2019, 04:22 PM   #10
Dachshund
Re: 1947 Guages
Yeah, the wiring was the main reason the truck was parked - it was BAD 20 years ago. I plan on installing all new. Not very much in the way of "accessories", just radio, and MAYBE a fan - otherwise pretty simple.
