09-24-2019, 12:28 AM | #1 |
Radiator Support Question?
Will A 67-68 Radiator Support Work On a 69 C10
I Thought They Were All The Same n BodyWorked Mine Only To Find Out They Are Different Anything I Can Do To Make It Work? I Know Where Theres a 69 Support But Too Far On The 68 And Will Modify To Make It Work Posted via Mobile Device |
09-24-2019, 07:03 AM | #2 |
Re: Radiator Support Question?
Yes but you have to change all the sheet metal to 67-68 to match.
09-24-2019, 09:57 AM | #3 |
The Sheet Metals Already Painted.
Guess I’m Out Of Luck and Have To Use a 69 Support. Damn Posted via Mobile Device |
09-24-2019, 10:20 AM | #4 |
09-24-2019, 12:00 PM | #5 |
09-24-2019, 10:46 PM | #6 |
The 68 will work fine, you need to install the headlight buckets from a 69-72 core support, to get them in the right spot, i install the grill and center the headlight in the bezel, then tack weld, remove grill for final welding.
09-24-2019, 10:47 PM | #7 |
Im almost sure i have a set of headlight brackets i could sell you if you need a set.
09-25-2019, 02:26 AM | #8 |
Thanks Guys. I Should Have a Spare Set Of Brackets On My Rusty 69 Support I Can Use. As Long As Thats The Only Difference I’ll Drill Out The Spot Welds This Week
Appreciate The Help Posted via Mobile Device |
