11-22-2020, 06:18 PM | #1 |
What vortec heads!!
I am currently rebuilding my 71 GMC 350. I have a torn apart in my living room, perks of not being married.
I’m looking for a good set of Vortech heads to buy. Also have a few questions. Which Vortech heads do you recommend? And do you have a link for them? My body was telling me I should get the ones that have 1.94 valves and have them machined out to 2.02 vowels instead of buying the 2.02 valve heads. Can this be done and would it be less expensive? I do know I need a Vortech intake but besides that I will probably go with a Lunati cam. I’ve been waiting all summer to do this now I got to get on it before I spend my savings. I believe I have flattop pistons. I am going through and cleaning and organizing all my parts and bolts I’m also going with roller rocker arms would also like a good part number on that if anybody had |
11-22-2020, 08:37 PM | #2 |
Re: What vortec heads!!
Below in the first link is the small block I put in my 68 c10 with vortec heads and a lunati cam. You can see it has 350 hp and 410 tq. Might be a good starting point to base your build off, one thing I would suggest is getting the second link as intake manifold gaskets as the vortec intake manifold only uses 8 bolts to tighten the intake down. If you don't drop the money for the manifold gaskets to start you will end up having to eventually as the gaskets without metal reinforcements will most likely leak causing a massive vacuum leak and oil burning situation like I had with mine.
https://paceperformance.com/Small-Bl...420194-VK.html https://www.summitracing.com/parts/f...iABEgJS6PD_BwE |
11-22-2020, 08:50 PM | #3 | |
Sweet I appreciate that. Do you happen to have any videos of how your build sounds |
11-22-2020, 09:44 PM | #4 |
I don't, here is a picture of it though. I'll see what i can do for video maybe get one for next weekend.
11-23-2020, 02:23 AM | #5 |
If you go for used make sure there not 305 heads and have them checked for cracks
Stock they have a cam lift limit to have checked out In my build I am using a Comp Cam Extreme 4x4 I ordered new heads from summit and had to get them machined for lift and like Leigh I picked up an Eldbrock profomer intake If you have Ac and one of those heater shutoff blocks insure you add a steam line for the heads Skogen Dicky https://sdparts.com/i-24502323 https://sdparts.com/i-23901396-sdpc-...g-upgrade.html |
11-24-2020, 12:13 AM | #6 |
Vortec heads and flat top pistons will yield a high compression ratio. Not sure if pump gas would be an issue.
1982 K10 SWB 1987 V20 - Sold - Doh! |
11-24-2020, 02:43 PM | #7 |
GM used dish pistons in the Vortec engines to keep the CR to a reasonable level.
Also, GM used a coolant bypass hose/tube. You need to do the same thing by routing a 1/2 or 5/8" hose (I used the same hose GM used), from the top of the water pump to the cross coolant passage next to the upper radiator hose. The ID of the fittings used will be the restriction, not the hose itself. The coolant bypass is necessary since Vortec heads do not have a hole that matches the coolant bypass in the old school GM blocks. Without it, your heads will develop hot spots and you will see wild temperature swings at the gauge. Another option is to drill some holes in your thermostat. This works the same as a bypass hose, but what if someone forgets to drill the holes during a thermostat change?.....
1971 C20 Custom Deluxe, HT383, 4L80E, 3.73 Locker, 4 Wheel Discs |
11-24-2020, 05:15 PM | #8 |
If you're lookin for a complete engine Jegs sells them with 3yr unlimited mileage warranty. The only difference I see between the one from Jegs I bought and the one Liegh222 bought is his has a smaller cc combustion chamber in the head and a bigger camshaft. The smaller cc heads and bigger cam would make more horsepower than the version I bought. The one I got I put a link below to it was a lot cheaper so a cam kit added you'd still have money left over. Not knockin his purchase at all in any way shape or form. I'm just throwing out there what I got as a comparison to try and help and to show options to think about. Anyway thats my two cents worth of input.
https://www.jegs.com/i/JEGS/059/8758/10002/-1 |
11-24-2020, 05:29 PM | #9 |
Here is a great article on Vortec Heads at Crankshaft Coalition.
http://www.crankshaftcoalition.com/w..._cylinder_head It answered all my question and more before I did my Vortec 350. |
11-24-2020, 05:55 PM | #10 |
No offense taken, when I bought mine the list price was $3,300.00 and they had a special for $250 off so It was about $1400 less when I bought it 2 years ago. Nothing like inflation during a pandemic.
11-25-2020, 10:14 AM | #11 | |
Sounds like you got a screamin deal hell a cam kit will cost ya $250. Sweet. Yea everyone seems to be gettin rich on the pandemic. Seems its either that ot political crap. Have a safe and Happy Thanksgiving |
