Old 11-05-2013, 09:38 PM   #1
Theoriginalsilverado
Exclamation Kinked and Bowed Hood
I'm sure if you haven't had it happen to your own square you've at least seen another square with the same problem- a kinked hood. It's a common problem. I was just wondering how you guys fix it.
I've managed to straighten mine out without detaching the hood, and making sure the springs are well greased afterwards- it will do wonders for the hood. But it'll still need straightening after time.
The only alternative I've found other than buying a new one or fixing the one you have is a hood brace kit from LMC, for a cheap $20.
Has anyone used the kit or have any advice pertaining to this topic? Please help me and many other square owners who have bows for a hood.
Check out the kit here:http://www.lmctruck.com/features/cc/cchbk.htm
If It runs like a Chevy, it probably is!
Theoriginalsilverado is offline   Reply With Quote
Old 11-05-2013, 09:53 PM   #2
rusty76
rusty76's Avatar
Re: Kinked and Bowed Hood
There's some other threads on here that goes into it a bit.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 11-05-2013, 10:11 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
The hood kinking is actually a safety feature GM designed into the 73-80 trucks.
I usually just spot weld a couple of pieces of flat strap on the bottom side of the hood over the kink points. Its a whole lot cheaper than buying a kit.
Tx Firefighter is offline   Reply With Quote
Old 11-05-2013, 11:25 PM   #4
y5mgisi
Second Chance Program
y5mgisi's Avatar
I have it on my 78 and it stopped the kinking.
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 11-06-2013, 12:40 AM   #5
tucsonjwt
I prevented the hood crunch on my 76 by keeping the hinges and big springs lubed - there is a lot of exposed steel there to get rusty even in the desert.
tucsonjwt is offline   Reply With Quote
Old 11-06-2013, 08:30 AM   #6
xrcr
I've added plug weld on the sides and steel underneath as well. However keeping it well lubed and when closing, pushing back, then down is a must
xrcr is offline   Reply With Quote
Old 11-06-2013, 11:35 AM   #7
Rnd
I put those LMC braces on my "77 so that the hood wouldn't kink. I wrenched in a Chevy dealership in the 70's those hoods would fold when they were new. $20 cheep and easy fix/insurance.
Rnd is offline   Reply With Quote
Old 11-08-2013, 11:40 AM   #8
blazer2007
dumg question but what did you use ,I used some spray but I think it made it worse
blazer2007 is offline   Reply With Quote
Old 11-08-2013, 08:33 PM   #9
cadillac_al
I think the owners manual says to use regular motor oil on the hinges. I'm surprised I don't ever see this. I have had about 5 squares over the last 30 years and never kinked a hood. My current truck hood was a little stiff last week and I oiled it. I have kinked a couple of my cutlass hoods years ago and I am sensitive to stiff hinges now.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 11-09-2013, 03:03 PM   #10
hatzie
Moderator
hatzie's Avatar
I use Wurth HHS 2000 and spray the whole spring and hinge down.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
chevrolet, gmc, hood, hood brace kit, kinked hood
