Old 06-29-2018, 08:37 AM   #1
msgtmac
Front end alignment
Putting my frame back together and I am needing advice and pictures of the upper control arm set-up and recommended shim starting point. Pulled shims out and put them in a bag before identifying. I am going to even out the shims front to back but can't remember where the concave washer goes. 1963 step side C10. Thanks
msgtmac is offline   Reply With Quote
Old 06-30-2018, 01:49 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Front end alignment
Good thread on the subject of washers: http://67-72chevytrucks.com/vboard/s...d.php?t=589541
Old 06-30-2018, 02:00 PM   #3
msgtmac
Thanks, I think I got the front end back together to where i will be in the ball park. Put the shim between the flat of the concave washer and the control arm shaft.
