03-20-2019, 10:58 PM | #1 |
Anti freeze on intake
Just wondering if you have any ideas how the antifreeze showed up on the front of the intake. My thought was from the thermostat housing. I have not drove The truck since I picked it up a few weeks ago. I fired it up this evening and was waiting for the thermostat to open up but I ran out of time and had to go make dinner. thought I would ask before I fired it up again.
03-20-2019, 11:15 PM | #2 |
Re: Anti freeze on intake
Sure it's not simply leaking from the upper radiator hose, right there? My intake had a small pool of coolant like that last week - turns out the hose was simply leaking slightly. I drained the system down a little, and had room to simply cut the hose back an inch and re-clamp on a fresh section. No more leak! Simple fixes are the best.
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER 1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD 1976 Trans Am | 400/4-spd | SOLD 1976 Trans Am | 455/4-spd | TOTALED |
03-20-2019, 11:19 PM | #3 |
I had something similar happen the other day, it was so cold that the hose to the thermostat neck leaked at the start before it warmed up. Tightened the hose and no problem since. I’d give that a shot, if nothing else it’s an easy check.
72 C20 with a 350 She's green like the Hulk, but the only thing she smashes is my wallet. |
03-20-2019, 11:24 PM | #4 |
I will double check the hose. I was watching it as it was warming up and didn’t see anything. but like I said I couldn’t wait any longer for the stat to pop open. I will double check this weekend. Thanks for the quick reply’s
03-21-2019, 08:40 PM | #5 | |
https://www.summitracing.com/parts/snn-12270 |
03-21-2019, 10:41 PM | #6 | |
low n' slo
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
03-21-2019, 09:29 PM | #7 |
I had this EXACT same thing happen to my truck. Brand new hoses, so I knew it wasn't that. Tried replacing the thermostat housing gasket, still leaked! Then I realized that the part of the thermostat housing that the hose slid onto was pitted and the hose couldn't get a good seal around the housing. Bought a new housing, problem solved!
If tightening up the hose clamp and housing bolts doesn't fix it, I'd check the thermostat housing where the hose slides on.
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801 |
