Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 11-24-2020, 12:57 AM   #1
svr
svr's Avatar
Paint vs thinner?
Just getting started painting my ‘57. Base coat, clear coat urethane. Doing a 2 tone gray and white. Data sheet calls for 2 parts color and 1 part thinner on basecoats. That mix works beautiful for the gray. When i use it for the white it is noticeably thinner. Hard to keep from making runs. Have thought of reducing the thinner in the white by 50% makeing the mix 2 parts color, 1/2 part thinner. That makes consistency much closer to the gray mixed 2-1. Question will reducing the thinner slow the flash point causing me to go slower between coats? Any thoughts appreciated, very rookie here.
57 short box, 235, T5, C4
http://67-72chevytrucks.com/vboard/s...d.php?t=739132
svr is offline   Reply With Quote
Old 11-24-2020, 10:16 AM   #2
nsb29
nsb29's Avatar
Re: Paint vs thinner?
It shouldn’t make any difference air pressure and gun adjustment for material flow will also make a difference
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
nsb29 is offline   Reply With Quote
