03-13-2017, 11:13 PM | #5101 |
Re: What did you do to your truck today? Chapter II
Bolted the steering gear and linkage up to the frame. |
03-15-2017, 09:51 AM | #5102 |
Thanks kilrcady. I tried the same but didn't have great results, so I went a different route. I put a decent gauge piece of black copper wire at the bottom - figured it wouldn't rot or rust. But, what really made a difference was cutting away a piece of the mirror swivel ball to allow for more adjustment range. I just used a metal cutting wheel on my dremel.
picture to get some perspective: closeup of the cut: closeup of the cut, 2: the result, from the driver's seat: I'll probably have to keep a good coat of grease in there to keep it from rusting, but at least it's useful now. |
03-15-2017, 03:52 PM | #5103 | |
03-15-2017, 10:20 PM | #5104 |
I knew that this new to me cab that I bought was going to need cab corners when I bought it, most do.
Also, being a member and a lurker for a while, I have seen quite a few interesting things that have been found in our trucks that was done by PO's. This has to be up there on the list Not only the spray foam, but they threw the cap in for good measure!
Matt Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=672655 "Father thank you for the gathering of friends, Father we give thanks for all the choices we've made because that's what makes us who we are, let us forever cherish the loved ones we've lost along the way and most of all THANK YOU FOR FAST CARS!" |
03-15-2017, 10:31 PM | #5105 |
Changed from a stepside to a fleet bed
03-15-2017, 10:57 PM | #5106 |
Stripped the truck down to the frame
03-16-2017, 10:08 AM | #5107 |
03-16-2017, 02:45 PM | #5108 |
Nice...I bought a '68 C10 a few years back that had similar issues....the rusted through trailing arms were masterfully covered with plasti-dip, dust & whatever else...good enough that I didn't catch it until I jacked up the truck one day & both rear springs fell out...it was a clean realistic job...best I've seen in a long time.
-Doug '05 RCSB Sierra 2WD '71 Sierra 2WD Longbed '98 Silverado K1500 Xcab...sold '72 Highlander"Raymond"...sold |
03-16-2017, 10:49 PM | #5109 |
Hey man 67 GMC Short Stepside 400 small block, turbo 350. Build thread:http://67-72chevytrucks.com/vboard/s...d.php?t=650603 |
03-16-2017, 11:15 PM | #5110 |
Yeah - it looked pretty creepy at first!
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
03-17-2017, 12:29 PM | #5111 |
finally measured the mileage since installing the 200R4 trans, got 16.5 in a mix of highway and around town(more highway to be sure) and I love the fact that I can hear the radio while running 65-70 down the road. Sppedo rolled over today so I ma back to zeros
1971 C10 long bed, fleet side. 200R4 Auto, leaf spring rear. power steering. |
03-17-2017, 01:43 PM | #5112 |
Door logo in progress
03-17-2017, 05:33 PM | #5113 |
Scored two arm rests to replace my "reupholstered" ones. They're not color coordinated but my elbow doesn't know the difference. LOL
Phil "Money is only a tool to create and achieve what you want most in life" PayPal: rodnrudy@comcast.net |
03-17-2017, 09:07 PM | #5114 |
I installed new caliper hoses from Speedway Motors. It took cutting off the original brackets and welding the new ones on, but they look like the answer to a week of searching, parts returns and frustration!
1972 C20 Fleetside "Miss Olive" http://67-72chevytrucks.com/vboard/s...d.php?t=721563 |
03-17-2017, 09:46 PM | #5115 |
Finished dismantling the cab less the front & rear windows and doors. I'll probably pull the hump as well, but space is a premium, so I'll save it for another day.
That and finished the first manual I'll be writing. At 75 pages it got too large (edit, reduce, standardize, edit, reduce, standardize.....Yikes).........so I figure one manual for body & windows, one for chassis & drive train, and the one I finished for all else. The next two should be much easier. Boring I know, but for me it's an adventure..........In 5-6 months I post actual restoration. The rebuild will be MUCH quicker....promise. I've received a TON of guidance through this website, and it's always appreciated,
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s details such as OEM identifications& part numbers, written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
03-17-2017, 11:35 PM | #5116 |
Nice Job, ShortBed!
03-18-2017, 12:07 AM | #5117 |
Ha, thanks. Sure have learned a lot. Can't wait for suspension and the rest of the e-brake. Haven't the slightest idea how the Ebrake cable it's connected at the frame. I'll figure it out after I pull the body. Can't wait to start painting something, starting with the frame. Still haven't settled on body color. That's been a constant since I bought it.
03-18-2017, 08:35 AM | #5118 |
Shortbed ,I love the current color ,dont see many like it anymore .
03-18-2017, 08:58 AM | #5119 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 Makes a lot of sense. Using a hook to apply pressure to the cable seems like it belongs on a Ford tractor. Don't worry about the color until after you've gotten along in the project. I'll bet it comes to you.
03-18-2017, 11:57 AM | #5120 | |
The second pic is another option. Third pic has become a recent ponder. If I had a 67 color would be easy........ Light blue and white.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s details such as OEM identifications& part numbers, written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 03-18-2017 at 12:05 PM. |
03-18-2017, 12:41 PM | #5121 | |
03-18-2017, 12:47 PM | #5122 |
Been hard it this morning. Install stereo and speakers last night and finally installed seat this morning; interior is done Except maybe a different steering wheel. Painted headers this morning and primer-etched valve covers. Lots of daylight left
03-18-2017, 03:18 PM | #5123 |
Doesn't take you all day to do a day's work. What did you use on your headers?
03-18-2017, 03:40 PM | #5124 |
03-18-2017, 05:05 PM | #5125 |
Installed plugs, wires, cap & rotor, changed the oil & filter & laid down some rubber! Gotta love old dried out tires!
