08-11-2019, 08:20 PM | #1 |
70 K10 Disk brake conversion
I'm sitting here in the garage dreaming about the future. Right now I'm knee deep in body work.
Is there a conversion kit for converting power drum brakes to power front disk? My truck is a 1970 4WD K10 Thanks Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those" 1969 Mercury Cougar Standard 4 speed 1969 Mercury Cougar XR7 convertible 1970 4WD Chevrolet Suburban 1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997) |
08-11-2019, 09:11 PM | #2 |
Re: 70 K10 Disk brake conversion
Swap in a Dana 44 from a newer truck with disk brakes already on it.
08-11-2019, 09:57 PM | #3 |
All about them K’s
Bingo this is the cheapest easiest route. The 71+ axles bolt right in.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
08-12-2019, 11:34 PM | #4 |
Thanks guys!
08-14-2019, 07:46 AM | #5 |
You can also just swap the knuckles on out onto your open knuckle housing. That way you can keep the factory gears and know you have the correct ratio. You still need a donor front, but you don’t have to worry about matching gear ratio that way.
08-15-2019, 09:47 AM | #6 |
The drum brake axles have a closed knuckle design where the disk brake axle is an open knuckle. The two designs are not interchangable at the knuckle. If you can't find a donor with the same gear ratio you should be able to swap the gears from the OEM housing to the donor Dana 44
08-16-2019, 06:59 AM | #7 | |
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
08-16-2019, 09:58 AM | #8 | |
All about them K’s
08-17-2019, 05:32 AM | #9 | ||
Steve |
08-17-2019, 07:20 AM | #10 |
I just installed the ECE disc brake conversion kit, highly recommend
08-17-2019, 08:22 AM | #11 | |
Using a complete or parts from a later model axle is the way to proceed. The main discussion seems to revolve around how many are aware of the ‘70 one year only drum brake open knuckle axle. And while the drum brakes can work and in some cases work fairly well, I can’t see spending the time and money to keep them for a vehicle that will see any time on the road, and if you off-road, if water crossings are ever on the map. I have a couple of jeeps that still have the drums in front, and the 11” conversion on my M38A1 works well, if it hadn’t still had the frame mounted master I would have done discs.
08-17-2019, 03:52 PM | #12 |
Years ago I drilled and installed backing plates from a 71 K10 for my 70. It took about 2 hours. Not a tough job at all , plus did not have to mess with matching axles. The rest was a complete bolt on application. I did have to replace the centering valve for disc brakes.
