03-11-2019, 01:39 PM | #1 |
1972 k10 cab question
Will a low hump cab work with a 700r4 transmission on my 72 4x4? I know from the factory they had the high hump but I'm not walking to cut the low hump out . My plan is to just put the high hump over the top and just cut what I have to for the shifter and probably use 2 boots. But who knows I might just cut the whole thing out.
03-11-2019, 08:27 PM | #2 |
Re: 1972 k10 cab question
I think it would be pretty tight?? I would install the high hump
03-13-2019, 03:06 PM | #3 |
Ttt. Does anyone have any pictures of the floor where the high hump bolts on. Wondering if its reinforced.
03-13-2019, 10:18 PM | #4 |
Roto Reuter thats the name...
It's not hard to replace the low hump with a high hump. There is no need to cut anything. They just bolt in place. Just unbolt the low hump, clean up the surface, and install a high hump. Here is a picture of my K10 4WD with the high hump removed. I have a couple of high humps that I'll probably be selling in the near future. Hope this helps.
~ Dan My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
03-13-2019, 11:11 PM | #5 | |
All about them Ks
Jcfcamaro yes the factory high hump floors have a reinforcement that welds to the bottom of the floor with spot welded nuts for the screws that hold the hump down.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's 87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue 10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
03-13-2019, 11:15 PM | #6 |
It's been a while, but I don't remember cutting the low hump out being a big deal. I think the cut lines are there. I don't think there are any special reinforcements. The factory nuts are welded to the bottom of the floor.
03-14-2019, 12:00 AM | #7 |
All about them Ks
This thread may help you see what a factory high hump floor looks like. Davis is correct the cut lines are already in the low hump floor.
http://67-72chevytrucks.com/vboard/s...d.php?t=779161
03-14-2019, 07:44 PM | #8 | |
My 71 swb with carpet still in place. Carpet removed Low hump cut out
03-15-2019, 02:07 PM | #9 |
Thanks Guys for the info and pictures.
03-15-2019, 05:30 PM | #10 |
Hey, could someone that has a factory cab with a high hump measure the hole opening and or the bolt holes on the rear of it to the bottom of the raised brace on the floor.
03-16-2019, 10:56 AM | #11 |
All about them Ks
I can but I won’t be back to my truck until Monday.
03-16-2019, 11:06 AM | #12 |
I did this on my 72...3/4 4x4 auto frame and running gear and a 2wd low hump cab.
you can cut the area out and use the high hump plate with self tapping metal bolts and it works fine.
1972 Cheyenne Super..owned since 1978 1972 Surburban 4x4 1972 Cheyenne 4x4 3/4 ton.....sold 1972 Cheyenne 2wd...named Death Row |
03-16-2019, 11:27 AM | #13 |
My main problem is the cab is sitting on a roller stand and not on my frame so I can't center up the transfer case shifter with the hole on the high hump. I know side to side is good but the front to back is what I'm worried about.
03-16-2019, 11:35 AM | #14 |
Currently Blazerless
Your transmission and transfer case will clear your low hump floor with no problems. You only need the high hump on 4 speeds. Plenty of clearance for trans and shifter with the automatic.
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
03-16-2019, 03:40 PM | #15 |
Ok, I have measured and have pictures of the cut out. Went out to a friend's house where he had a 4x4 cab sitting. Now to decide to cut the low hump out or just leave it and bolt the high hump ontop.
03-18-2019, 12:39 PM | #16 |
Well I went for it Saturday and it wasn't so bad.
