Old 06-30-2020, 11:07 AM   #1101
Green Monster
Green Monster's Avatar
Re: What did you do to your Blazer/Jimmy today?
New black differential covers- front and back.
Green Monster is offline   Reply With Quote
Old 06-30-2020, 03:07 PM   #1102
scott123
Today I pulled out the automatic column and started the rebuild on it. Clean, sand, prep and paint to back into the 72 Blazer.
I'm changing over to an automatic but doing it one step at a time. Column first. Transmission lines on the ready and then the swap to the TH350/NP205. After that the pedal assembly.
Trying no to leave it crippled as it is a blast to drive.
S
scott123 is offline   Reply With Quote
Old 07-02-2020, 11:20 AM   #1103
lks dcvn
lks dcvn's Avatar
If somebody is ever considering painting the firewall black on their trucks...don't do it. Spent the past few days lightly wet sanding off the black rubberized paint off the upper firewall of my 71 4x4 Blazer project.
I was able to get back to the original firewall crayon markings for 518 - which is the stock 71 Medium Green paint code - so I thought that was a win for the time invested. It was on both the driver and passenger side of the upper firewall.
A few before, during and after shots...
lks dcvn is offline   Reply With Quote
Old 07-04-2020, 11:55 PM   #1104
Ptjsk
Took it out for it's first long drive. Ran great!
Pat
Ptjsk is offline   Reply With Quote
Old 07-05-2020, 09:53 AM   #1105
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Congratulations and it looks great
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 07-06-2020, 09:24 AM   #1106
C.I.Blazer
Pat, what are you running for lift and tire size / type? Your truck has a great stance. Thanks.
C.I.Blazer is offline   Reply With Quote
Old 07-06-2020, 02:59 PM   #1107
Ptjsk
Thanks Bud!
I took the original springs in for re-arching and asked for 2-2.5" I think it's a bit more than that though.
Also, I just put 2" blocks in the rear.
The tires are 33"x12.5"x15". They are the new BFG KO3's on 15" x 8" rallys. I picked up a set of 15" x 8" steel wheels and have sandblasted and painted them white. Now, I'm not sure if I want to swap them out or not.
I'm afraid it's going to squat down a bit when I put the top back on.
I think I'll put in a couple of overload air bags so I can bring it up a bit if I have too.
Thanks for the kind comments!
Pat
Old 07-06-2020, 08:23 PM   #1108
SeventyOne
Installed a phenolic spacer under my carb to solve a heat soak hard start issue I ran into. also playing around with the AFR gauge and carb settings to dial it in
SeventyOne is offline   Reply With Quote
Old 07-07-2020, 07:55 AM   #1109
C.I.Blazer
Thanks Pat. Exactly the look I am going for. The truck I bought has 35" Mud Terrains with what I believe to be a 4" lift. Too tall for my taste. Appreciate the info.
Old 07-07-2020, 06:53 PM   #1110
Ptjsk
Yea, it was a tough decision, but I agree with you. Although I think they still look good, the 35's with a 4" were just a bit too much for my preference.
Adding some air assist lifting bags to the rear soon. They're supposed to arrive today.
I want to be able to tow a small trailer with no sagging.
Pat
Old 07-08-2020, 08:03 AM   #1111
craneboy72
craneboy72's Avatar
Installed my GM copy steps I pitched on the forum
craneboy72 is offline   Reply With Quote
Old 07-08-2020, 10:27 AM   #1112
Ol Blue K20
They look great.
Dale
Old 07-08-2020, 05:09 PM   #1113
craneboy72
craneboy72's Avatar
Thank you they are made well and are very helpful getting in
Old 07-08-2020, 07:54 PM   #1114
Ol Blue K20
I'm sorry, I forgot to tell you how nice the Blazer looks!
Dale
Old 07-08-2020, 11:39 PM   #1115
Ptjsk
Very nice....clean looking Blazer!
And the steps look great too!
Pat
Old 07-08-2020, 11:42 PM   #1116
Ptjsk
Did your (large) spare tire work with the original spare tire holder?
Thanks,
Pat
Old 07-08-2020, 11:57 PM   #1117
Green Monster
Thanks,
Pat
I am using the original spare tire carrier with a 33x12.5R15 BFG KO2. So far I replaced the carriage bolt with longer than stock but needs a little more modification to make it fit right. The carrier needs to about 6 inches taller. A metal box (open on the bottom) that fits over the carrier to serve as an extension will probably work.
Old 07-11-2020, 08:51 PM   #1118
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
I'm having TOO much fun driving my 71 this summer to do anything to it.
I took it to work all this week.
Shot this pic leaving one day.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 07-13-2020, 11:08 AM   #1119
simicrintz
Great pic! On the Jeepster page that I am on they do a calendar and have folks submit pics for it; this would be great in a Blazer calendar!
-Bruce
1971 K5 Blazer 4WD
simicrintz is offline   Reply With Quote
Old 07-13-2020, 03:31 PM   #1120
Ptjsk
Are those 15" x 8", or 15" x 10"?
Thanks, Pat
Old 07-13-2020, 04:05 PM   #1121
craneboy72
craneboy72's Avatar
Thanks, Pat
15 x8 off a m1009 blazer
Old 07-14-2020, 12:32 AM   #1122
Ptjsk
Cool, thank you!
Pat
Old 07-14-2020, 12:42 AM   #1123
Ptjsk
Put my top on!
Can almost say it's finished......even though they never really are.
Pat
Old 07-20-2020, 08:29 AM   #1124
hemi43
hemi43's Avatar
Finally got my master cylinder installed. I had used a 2003 unit because it had a 1 1/4" bore, but went to the Wilwood with a 1 1/8" bore for better pedal feel and stopping. I got lucky and was able to get it on without bleeding, but I may do it anyway just to make sure there's no small air bubbles.
hemi43 is offline   Reply With Quote
Old 07-20-2020, 06:11 PM   #1125
mister.freeze
mister.freeze's Avatar
flushed the radiator, remounted and wired the fans. Last time I did that was 20 years ago, so I figure I'm good for another 20.
'72 K5, known as 'the Fox.'
mister.freeze is offline   Reply With Quote
