Old 11-07-2020, 08:29 PM   #1
James Pierce
Rockwell T 221 N7 Transfer case.
Where do you find parts and gasket sets for these cast iron monsters? They have shims and clearances is there a manual available as well? They are mated up to SM 465 xmissions. Have a 69 C20 with split rims would like to build a crawler out of it.
cascadeheavychevy
67 C10 327 4speed
69 C20 350 4WD 4speed
69 C20 350 4 soeed
69 C20 CST 350 Auto
70 C10 307 4speed
71 GMC Supr 350 Auto
70 C10 350 Auto
67 CST 327 Auto
James Pierce is offline   Reply With Quote
Old 11-07-2020, 08:39 PM   #2
franken
Re: Rockwell T 221 N7 Transfer case.
Maybe think about doing an internet search of what's in the subject minus the space after the T.
Old 11-07-2020, 09:19 PM   #3
James Pierce
Same result space or no space.
cascadeheavychevy
67 C10 327 4speed
69 C20 350 4 soeed
69 C20 CST 350 Auto
70 C10 307 4speed
70 C10 350 Auto
67 CST 327 Auto
Old 11-07-2020, 09:44 PM   #4
franken
Really? First hit in the following link is a manual.
There should be plenty of reading in the links in the searches.
https://www.google.com/search?q=Rock...hrome&ie=UTF-8
This searches this site:
https://www.google.com/search?sxsrf=...4dUDCA0&uact=5
I've read that bearings and seals can be had since they're standard. I recall seeing a post with numbers, etc. but don't ask me where it is.
Old 11-07-2020, 10:04 PM   #5
evan396
Take lots of pictures when you take it apart. Bearings aren't to bad to get, seals are probably going to be tougher since they have to be crossed reference so save the old seals to measure. Lots of info on the web. Just have to look around. Name:  20200306_185358.jpg
evan396 is offline   Reply With Quote
Old 11-14-2020, 06:23 PM   #6
WyoRoadDog
Page intentionally left blank.
WyoRoadDog's Avatar
I bought a kit earlier this year from Torque King 4x4. Had everything I needed, plus some (they must include extra parts for variations).
https://torqueking.com/category/1967...transfer-case/
There is a theory which states that if ever anyone discovers exactly what the Universe is for and why it is here, it will instantly disappear and be replaced by something even more bizarre and inexplicable.There is another theory which states that this has already happened. - Douglas Adams
'67 GMC 4x4, 305 V6! Or all the parts for anyway...
'17 Subaru Outback.
'18 Toyota Tacoma TRD Off Road.
'99 Ducati 900SS.
WyoRoadDog is offline   Reply With Quote
Old 11-16-2020, 04:34 PM   #7
Short 3/4
I've also had good luck with Torque King. Good parts, good people.
65 short stepside K10
292-SM420-T221
8 lug closed D44 front
NoSpin HO72 4.10 rear
Short 3/4 is offline   Reply With Quote
Old 01-09-2021, 12:28 PM   #8
aotte1
Using TorqueKing too. Also might consider SKF seals for input and output shafts.
They are a newer design material that has a higher temperature rang-400 degrees, along with compatibility to newer lubricants. part number SKF 17387.
(Make sure latest design/material) Also consider using two on each shaft.
aotte1 is offline   Reply With Quote
