03-03-2021, 02:28 PM | #1 |
Wheres the Leak
Hi all, got a question. Have a 1968 c10 with a 350 from a 70-80s truck, but P.O. said it leaks coolant not bad just enough to notice. Starts right up and idles just fine. It has cast heads so I think the head gasket would've blown before it warped the head, had it running for 5-10 mins and only thing I noticed was a small drip running down where the oil pan meets the block running along the length of the block (was parked on a hill). Seems to be coming from driver side. No sure if I have a hair line crack in the block, a head gasket issue, warped head or a bad freeze lug near the motor mount. Any info would be appreciated still really new to mechanic work.
03-03-2021, 02:43 PM | #2 |
Re: Wheres the Leak
Any water in the oil?
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
03-03-2021, 02:55 PM | #3 |
Re: Wheres the Leak
Use baby powder to find oil and water leaks . watch the video .
https://www.google.com/search?q=usin...rj_Aaxna3YBQ27
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
03-03-2021, 02:58 PM | #4 |
Re: Wheres the Leak
03-03-2021, 02:59 PM | #5 | |
Re: Wheres the Leak
03-03-2021, 03:05 PM | #6 |
Re: Wheres the Leak
Two main places look around the intake for leaks
And look at the water pump there is a weap hole it may leak from as well |
03-03-2021, 03:06 PM | #7 |
Re: Wheres the Leak
Check the weep hole on the bottom side of the water pump.
I had one leak and the coolant showed up on the trans inspection cover. Coolant ran on the oil pan rail from the pump to the back where it showed up. |
03-03-2021, 03:15 PM | #8 |
Re: Wheres the Leak
03-03-2021, 03:27 PM | #9 |
Re: Wheres the Leak
You can buy a green dye to put in the radiator to check for leaks.
03-04-2021, 07:53 PM | #10 |
Re: Wheres the Leak
Ok folks got some pictures tomorrow gonna grab some coolant, some of the items above and a cooling system pressure tester. This is the only place on the block I could find coolant. Personally believe its the freeze plug behind the engine mount. Also the heater core isn't hooked up, I should plumb that up before pressure testing right?
03-04-2021, 08:22 PM | #11 |
Re: Wheres the Leak
No need.
Actually better without it hooked up. |
