Old 07-16-2019, 03:01 PM   #1
andrewpclayton
andrewpclayton's Avatar
Shift indicator is off to the left
Hello all.. I know there are some threads on this already but none seem to be what I need..
I got this column from another 69 and I’m using it with a th350. The indicator is way off to the left. Is there a way to slide the column part that has the indicator over to line these up? Can just the part of the column the rod connects to be rotated?
1977 SWB (c20 conversion) SBC350
Springfield Oregon
Instagram: @nevernotchevy
andrewpclayton is offline   Reply With Quote
Old 07-16-2019, 03:55 PM   #2
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: Shift indicator is off to the left
Don't remember the anatomy there for sure, but is the transmission in Park with the lever in that position? I'd think that the linkage only needs to be adjusted. To do that, block the wheels, and put the truck in Drive, and adjust the linkage rod. There is a detent for the lever inside, so make sure that lines up, too.
~Steven
Simi Valley, CA
Old 07-16-2019, 07:18 PM   #3
70shortfleet
70shortfleet's Avatar
loosen the nut at the column that holds the connecting rod from trans to column, then put trans in neutral and put shift lever on column in neutral, trans and shift lever in neutral is a good place to start, then retighten the nut that you loosened at 1st. See if that helps
70shortfleet is offline   Reply With Quote
Old 07-16-2019, 11:51 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
I always use the Park position for the adjustment and here is why. The park detent on the shifter arm has to lock behind the raised bump on the shift selector plate. The only way to insure that the detent is in the correct position is to have it in that position and the transmission in park when the adjustment lock bolt is tightened up on the shift rod.
LockDoc
Leon
Old 07-17-2019, 01:11 AM   #5
Fbks_Cruiser
Fbks_Cruiser's Avatar
And after you have adjusted the linkage so that the pointer is properly aligned, you may have to adjust the neutral safety / backup lamp switch.
1972 GMC K2500 Super Custom
Matt
Fbks_Cruiser is offline   Reply With Quote
Old 07-18-2019, 10:40 AM   #6
andrewpclayton
Even if I have the rod disconnected I have no play in the indicator position via the piece with the detent and the piece that holds the rod. Am I missing something or not thinking about this the right way?
Springfield Oregon
Old 07-18-2019, 11:24 AM   #7
LockDoc
LockDoc's Avatar
It depends on where your detent bump on the arm is sitting on the shift selector plate. People tend to think that the park position is all the way past the plate, but it isn't. It has to sit on the plate and rest against the raised bump on the plate. (see picture) This raised bump is usually worn down (like this one) and may need to have a bead of weld layered on it and dressed back up to factory specs. That is why you have to pull the shift lever back toward you to shift the transmission into the park position, to get the arm detent over that boss.
LockDoc
Leon
Old 07-19-2019, 10:53 AM   #8
Katrina/10
Katrina/10's Avatar
LockDoc
Thank you Leon! For years I have wondered why my pointer goes so far to left, now I find out I was doing it wrong. I'm going to try to readjust my shift rod today, and see how it works.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 07-19-2019, 11:40 AM   #9
LockDoc
LockDoc's Avatar
Let us know how it goes.
LockDoc
Leon
Old 07-19-2019, 12:11 PM   #10
Keith Seymore
Keith Seymore's Avatar
LockDoc
We used "N" in the assembly plant because it takes any assembly variation and spreads it across both ends of the range of shifter motion.
Out in the real world - I always use Park as well. That's the spot we really care about.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 07-19-2019, 03:02 PM   #11
Steeveedee
Who Changed This?
Steeveedee's Avatar
Go here and follow the procedure detailed in the transmission section. The reason for having the shift selector in drive is because it is imperative that the detent in the transmission is set with the roller at the bottom of it, so that full pressure is allowed to flow in the transmission. If this is mis-adjusted, early failure will result.
http://67-72chevytrucks.com/vboard/s...ghlight=hatzie
~Steven
Simi Valley, CA
Old 07-21-2019, 12:26 PM   #12
Katrina/10
Katrina/10's Avatar
LockDoc
The adjustment was a success! Easiest thing I did that day. Everything lines up better and the neutral safety switch works like it's supposed to. The shift lever does hang a little lower when it's in drive, but not too bad. I'm really glad I read this, it's been bugging me for a long time.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
