03-27-2017, 12:59 AM | #1 |
Any advice for a novice stripping under-carriage & drive train?
71 C-10 402/400 I'm perfectly green going into this. Can't wait to ID all the parts (so fun )........I've stripped the cab less front/rear windows, but essentially the undercarriage & drive train are a cab cart away. For what it's worth, I'm brushing the frame, and this is all in my garage less body/paint.
1. At some point the entire frame needs to be on stands. Is it safe to use a floor jack (on rollers) on the front or rear with the other side on jack stands? Very gradual? Other options? I've brought up the topic before, but something about visualizing a truck falling gives me the shivers. 2. In what order should I remove the following, generally speaking? It's all coming off.
3. Specialty tools? I know a pitman arm puller, and I think a coil spring compressor. Prefer using the right tools. Rust isn't an issue. Lucky for a first project. Thank you for any input.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s details such as OEM identifications& part numbers, written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 03-27-2017 at 01:22 AM. |
03-27-2017, 01:26 AM | #2 |
Re: Any advice for a novice stripping under-carriage & drive train?
After doing the A/C cab and most of the engine compartment, surely there aren't as many parts...HA! I'm only rebuilding the shell of the engine, less maybe a new oil pump? 40K on it (1993). Not sure about the trans. 140K, but sure shifts nicely. Probably needs a new switch "pass through" for kick down.
CAN'T be near as many parts. I identified the end of every including gauge and color. Less inside the fuse panel anyway. Color cuz I'm colored blind, but I got to the point I can see THESE colors.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s details such as OEM identifications& part numbers, written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
03-27-2017, 06:26 AM | #3 |
Break down sequence
Complete front clip off Remove bed Remove cab Remove driveline Place frame on 4 jack stands high enough to remove suspension if your unsure with any of this guideline Get Help . Never use a floor jack as a replacement for jack stands , use your engine lift to help hold/ lift the frame . Do you have all the tools and equipment to safely do all this ? Posted via Mobile Device |
03-27-2017, 07:46 AM | #4 |
Take lots of pictures.Time flys when your having fun. 4 or 5 years later you will be scratching your head did that go this way? Don't ask me how i know.
03-27-2017, 10:26 AM | #5 | |
Grumpy is right & your order in #2 is correct except suspension will be last. Remove the heaviest stuff first. With the front clip off you can remove the engine & trans together if you choose (even easier with the cab off too!) |
03-27-2017, 10:49 AM | #6 | |
03-27-2017, 02:00 PM | #7 | |
I take it the truck needs to be lifted to remove the front coils and all shocks? The front clip, bed and cab will be off before I dive into the suspension, drive train and drive line.
03-29-2017, 06:32 PM | #8 |
Let me ask, does it make much difference to remove the front coil spring with or without the weight of the engine? Looking at Youtube, it doesn't seem to make a difference if using spring compression tools.
