Old 02-19-2019, 08:44 PM   #1
obijuan
Hood ornament tech
What in the hell is the application difference between these hood ornaments?
They are 1981 only 5.7 diesel. Part numbers under are the same as just the run of the mill hood ornament.
I cant find any documents on them specifically.
Secondly, the yellow one has a busted stud so I need to swap it to the other one. How can I do this without hurting myself? lol
Or suggestions for repair on the yellow one.
1985 k5 396/nv4500/203/205 d60/d70 4.56 42 sx2
1991 V3500 350/4l80/205 60/14 4.10 35 toyos.
obijuan is offline   Reply With Quote
Old 02-20-2019, 11:55 PM   #2
truckin 79
Re: Hood ornament tech
Yellow is for Chevrolet and Red is for GMC. Push spring a little past hook part of hood ornament and tape ends together. The spring should slide off and to put back together do the opposite. Push spring down as far as you can and hook with one side of it. Cut the tape and slowly twist spring till it is at the top of spring
79 Chevy 2wd BIG10 350 TH400
truckin 79 is offline   Reply With Quote
