04-23-2011, 02:11 AM | #1 |
looking for step side fuel filler hose
Looking for a fuel filler hose for 1977 chevy step side any help finding a place or catalogue that sells them would be great.
04-23-2011, 08:27 AM | #2 |
Robert Olson Transport
Re: looking for step side fuel filler hose
Lmc
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
04-23-2011, 08:29 AM | #3 |
2017 Silverado LTZ 6.2 1984 Scottsdale K10 - 468 700r 4x4 lwb 1978 GMC Sierra Grande K15 350 Soond to be 406 th350 4x4 swb 1968 GMC 20 305 V6 good ole wood hauler. Good Fences make good neighbors |
10-30-2012, 08:31 PM | #4 |
I'm having the same problem. LMC sells them for fleet side, not stepside. I've tried a fleet side hose and it doesn't have the right bends. I've tried radiator hoses, but the inlet for the tank is a different diameter than the filler neck. You need a hose with different diameter on each end.
Has any stepside owner out there figured out a solution to this? Posted via Mobile Device |
10-30-2012, 11:35 PM | #5 |
Active Member
As far as i can tell no one makes them,Classic industries has one on it's website but when you go to check out ,it's discontinued.
10-30-2012, 11:47 PM | #6 |
I made one out of 1/4 bend a 90 bend gates gas hose and a steel pipe bent in to a c and connected them with fuel clamp it works and looks great
10-31-2012, 12:01 AM | #7 |
I think I'm going to have to make something also. I have two hoses that would probably work if I can put them together with some type of 90 and hose clamps.
10-31-2012, 12:51 AM | #8 |
You'll def. have to make something to suit. Nobody sells these. I had a heck of a time when I converted to EFI - I basically did the same as samstheman. Use Gates 24717 for 2", 24718 for 2 1/4" and 24719 for 2 1/2". Available at O'Reilly's.
Proud UA member since 2009 My LT1 Silverado build-up: http://67-72chevytrucks.com/vboard/s...d.php?t=549660 Check out my new YouTube channel! - https://youtube.com/channel/UCXk5mZOQI1sEnu5bIkhe7fA |
10-31-2012, 08:38 AM | #9 |
Thanks for the part numbers!!! Can one of you guys who have done this post a pic of the end result? Thanks again.
10-31-2012, 09:27 AM | #10 |
LMC does not sell them. I have a 87 long bed stepside filler neck sitting around at home. It has the screw in cap. I'll compare it to one of my shortbox stepsides.
1973 k20 Suburban 350 1974 Custom stepside c-10 250 1975 Chevy stepside 454 1986 K30 Crewcab SRW 350 R.I.P- glimmertwin01- board member and good friend, you will be missed |
