Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 09-02-2019, 07:19 PM   #1
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
how do i fix this
So cut out the bedside on my truck to fix a rotted section. I guess I welded it wrong because I didn't tack it and come back and forth along the seam. Where the panel meets along the top of the patch it is warped out... Do I heat the metal up and throw a cold rag on it hammer it down or what ?
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 09-02-2019, 07:56 PM   #2
mongocanfly
mongocanfly's Avatar
Re: how do i fix this
A shrinking disc followed by compressed air or wet rag would help....did you hammer and dolley the welds any?
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 09-03-2019, 02:40 PM   #3
old Rusty C10
not yet
this is now two days old since I did this weld
Bob
I hate cancer!!
Old 09-04-2019, 01:19 PM   #4
MP&C
MP&C's Avatar
That gap should have been non-existent. You want them as absolutely tight as you can get them. More weld to fill in the void, more heat, more shrinking, and nothing to keep it from pulling together as it shrinks. A good pair of OFFSET Wiss or Midwest shears, right and left, would have done a beautiful job of trimming for your patch. Cut the patch to size, scribe onto the quarter, cut out leaving 1/4" extra, then cut the last 1/4" right on the line. Don't use cutoff wheels, the heat introduced is adding distortion before you even get started.
this is a good place for a refresher video..
https://www.youtube.com/watch?v=qAOQfUaRZyw&t=41s
At this point I would suggest grinding down the weld to just above panel surface before planishing (hammer and dolly) to add some stretch back in from the weld shrinking. If you leave all that weld there, you have too much mass to try and stretch.
Robert
MP&C is offline   Reply With Quote
Old 09-06-2019, 08:05 PM   #5
tinydb84
tinydb84's Avatar
I honestly would cut it out and start over. Get some more practice in first too. It will save you in the long run.
David
Instagram: myfabguy
Old 09-10-2019, 02:21 PM   #6
Marty68
it also looks like you were trying to weld a "bead" I tack then go to other end of patch back and forth back and forth. I then grind ONLY THE WELD with the edge of a cut off wheel on die grinder.. let cool and tack back and forth again. grinds again. then shine a light behind if at all possible to see pin holes.... if after market bax sides are available that may be your best bet at this time. working that large of an area of filler is frustrating for me.
Marty68 is offline   Reply With Quote
Old 09-20-2019, 01:16 PM   #7
Stormin08
Stormin08's Avatar
Agreed....star over, or better yet just replace the bedside and be done.
Stormin08 is offline   Reply With Quote
Old 09-26-2019, 07:24 AM   #8
Marty68
those bed sides are fairly simple to replace. a small weld at the back and a bunch of bolts
